ENGINE MANUAL HELP?
wc9550
ENGINE MANUAL HELP?
#1 Post by wc9550 » Sat Dec 30, 2017 7:12 pm
Hey guys I just picked up a second boat and it has a different engine than the first one. This boat has a 1978 Mercury 700 outboard on it. I am wondering if there is a way to get an engine manual and parts manual? Is there a place I can download them or buy hard copies? I went to try cranking the engine today and found it wouldn’t crank. Doing some checking I found there was battery voltage at the main incoming lead. I had ground at the coil and when I turn the key to crank position, I had battery voltage at the other side of the coil, but the coil didn’t close and crank the engine. I’m hoping to get these manuals so I can get part numbers and R&R procedures. Thanks for any info guys.
Ryan
2019 South Bay 224SB2 3.0 tritoon with 2019 Merc. L200
boocat
Re: ENGINE MANUAL HELP?
#2 Post by boocat » Sun Dec 31, 2017 8:34 am
wc9550
#3 Post by wc9550 » Sun Dec 31, 2017 10:50 am
Thanks boocat. Gonna look into that site
FLOUNDERPOUNDER225
#4 Post by FLOUNDERPOUNDER225 » Tue Jan 02, 2018 10:15 am
contact this guy Bill Kelly, friend of mine down here in the Panhandle. He's forgotten more about Mercury Outboards than most ever knew.
http://www.maxrules.com/fixmeetbill.html
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
wc9550
#5 Post by wc9550 » Tue Jan 02, 2018 8:03 pm
Flounder: thanks for the link. I’ll try contacting him tomorrow and see if he has any manuals or anything. Thanks again guys
Retired OG
#6 Post by Retired OG » Fri Jan 05, 2018 7:35 am
I picked up a 1972 service manual for my 50 hp Evinrude on ebay for $24...my old motor now runs as good as new....There is no substitute for a "Motor Specific" factory service manual....
wc9550
#7 Post by wc9550 » Fri Jan 05, 2018 2:28 pm
Retired: yeah I am really hoping to find my specific manual. I’ve tried Ebay and haven’t had much luck there. I would like to get it running great and keep the motor, but have gotten some info saying no it’s a bad motor? Either way all I need it to do is last me a few years and then I’ll upgrade boats. Thanks for the info
Retired OG
#8 Post by Retired OG » Sat Jan 06, 2018 7:42 am
The guy who sold me the boat and motor I have now, thought the motor was bad too...Well, some of the components were bad and MOST of the previous attempts to "tune" it, were obviously done without the aid of a service manual, but the motor itself had GREAT compression....In all, I had to replace the stator, rectifier, timer base and trigger, ignition switch, spark plugs and clean, rebuild and adjust the carbs...the service manual made it easy...
Retired OG
#9 Post by Retired OG » Sat Jan 06, 2018 7:50 am
wc9550
#10 Post by wc9550 » Mon Jan 08, 2018 5:35 pm
Retired: are you sure that manual would work? If so then I’m gonna buy it Tonys guy. Thanks again man for your help.
Retired OG
#11 Post by Retired OG » Mon Jan 08, 2018 8:06 pm
It looks good to me, but there's no way to know for sure unless I could thumb through it....Reading the item description, I'd go for it....
wc9550
#12 Post by wc9550 » Mon Jan 08, 2018 8:25 pm
Retired: thanks for all your help. Gonna buy it tonight. Thanks again. I’ll send you a PM when I get it and show ya a few pages of it.
Retired OG
#13 Post by Retired OG » Tue Jan 09, 2018 9:11 am
Sounds good....The motor isn't froze up is it?
wc9550
#14 Post by wc9550 » Wed Jan 10, 2018 6:47 am
Retired: the engine isn’t seized. It does have a bad starter solenoid though. I was able to jump 12v to the starter and crank the engine. I tested compression on all 3 cylinders and had over 130 psi on each. Plus I was able to jump 1/2” gap during spark check. The entire reason for this thread is so I can get the engine and Parts manual so I get the exact starter solenoid for the engine. I did find a PDF of a manual (I’ll try to link it here and maybe you could check it out to see if I have the right one for my engine). Thanks again for all the info/help
Here isn’t the link/PDF I found. Hopefully it works
https://public-mercurymarine.sysonline. ... 1637450162
Retired OG
#15 Post by Retired OG » Wed Jan 10, 2018 12:39 pm
All I got when I clicked the link was a blank screen...I wasted a couple/few months of my time trying to garner "free" information on the web (most of it was wrong)...the good news is that you have really good compression and it appears you're pretty savvy with engines....I'm pretty fair myself, but I think I'd still be working on it if I hadn't had the factory service manual....
I'll also say up front that I thought I was smart enough to circumvent some of the steps in "tuning" my motor and it wasn't until I made my SECOND "maiden voyage", that the specific steps listed in the manual made sense...
