Metal roof while in transit
Posted: Mon Mar 05, 2018 5:27 am
by bansil
I am getting conflicting info about keeping our hardtop up while transporting it to the lake
Lake is 20 min. away at 45 mph
I think it will be fine seems sturdy enough, no electrical wires or bridges to worry about
Re: Metal roof while in transit
Posted: Mon Mar 05, 2018 6:29 am
It would be okay
Posted: Mon Mar 05, 2018 7:03 am
by Retired OG
My old Kayot has a hard top too but I'm running a GPS antenna and electrical on it and I'm building it to make it a permanently upright top....I've noticed that the front of the hard top slopes forward a wee bit and the legs on the forward half are shorter....my current plan is to build benches/seats near the legs of the top for side rail support where the roof legs bolt up....I also want to run easily removed cables with eye hooks and small cable tensioners from each of the four corners of the roof, to the opposite sides for times it might be subject to high winds...I'm also going to run cables on the front and back....My advice would be to figure out a way to better strengthen and stabilize the roof against high wind. I could probably get away with doing it with rope, but for just a few more $ I can make it stronger and last forever.
Posted: Mon Mar 05, 2018 8:50 am
by bansil
Good to know, I need to measure ht first before I make it permanent so I know bridge clearance
If it is short enough (so I can leave roof up), I plan to tie it into a front extension so almost whole boat will be covered when needed
I need to start a build...urgh..re-build thread
