"Instant" transducer mount. Flex Glue?
I just switched my TV provider so I've been exposed to some newer infomercials. There's one that's a squeeze tube of paste adhesive that makes an instant bond, even underwater.
My toon doesn't have brackets on the ends so last year I bought a transducer mounting base that comes with a slow-cure epoxy (my assumption) to glue it to the end of the toon. It looks too runny in the clear tube to fill the gap between my curved ends & the flat mount. The infomercial Flex Glue stuff looks ideal since it's thick, bonds instantly, and permanently... so they say.
Anyone ever try it?
Anyone ever try it?
Mark
Rush Lake, Atlanta, MI
Re: "Instant" transducer mount. Flex Glue?
Interesting, got a link? 3M 5200 works great...except it takes about a week to cure (out of water) and it is permanent
Google "Flex Glue" to find reviews (good & bad), videos, commercials, and lots of comments that infomercials typically attract.
The bad reviews seem to be mostly about curing time. There aren't many who disagree with the claim that the glue is press-and-done instant stick.
Mark
I notice there's a Fast-cure Marine version of 5200. I might try that. Or I might try an epoxy putty. That PC-7 epoxy has been holding golfballs to pop bottles for decades in hardware stores. Hard to beat that track record!
Mark
Yeah, but it does take a few days for a full cure....my transducer is mounter under my transom with a few gobs of PC holding it in place.
One of the issue glue "stuff" to aluminum is how fast the metal oxidizes after cleaned. Make sure to get any adhesive on quickly after sanding and cleaning the metal.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
I'd use 3M 4200 fast cure. If you ever want to move, remove or otherwise dink with your mount 5200 is not the stuff...
3M™ Marine Adhesive/Sealant Fast Cure 4200 is a general purpose adhesive/sealant that allows parts to be disassembled without damaging wood or fiberglass. It is a one part polyurethane that cures with moisture for flexible bonds.
- Exceptional sealing/bonding properties
Above or below the waterline use
Fast Curing
After speaking with a 3M engineer yesterday I'm now considering their VHB 5952 mounting tape. it's heavy duty, conformable, stays full strength underwater, and meant for slick plastics like polypropylene & polyethylene.
I suppose Stern Saver has a good reason to make glue-on mounts using a type of plastic that nothing sticks to.
Mark
