Craig thanks for the trimmer line idea!! I ran it in as far as I could (about 3 feet) and turned it several times, fired it up and boom had a full stream and no horn.
You Da Man
Can use some help
Re: Can use some help
fredeboy wrote: ↑Fri May 04, 2018 7:13 amWell the impeller was replaced mid last season when we swapped this motor on. Only had the boat out 3 times after that due to medical issues. One thing I noticed last night when I started it up was the pee stream was not solid. It would have a little spurt about ever 3 to 4 seconds. Any thoughts on that appreciated.
When you replaced the impeller, did you also replace the other rubber parts??? A few years ago, I had the rubber that holds the water tube on the water pump rupture on the side...it had the same symptoms....I now do the complete rebuild every year.
