Can use some help
fredeboy
Re: Can use some help
#16 Post by fredeboy » Sat May 05, 2018 11:01 am
Craig thanks for the trimmer line idea!! I ran it in as far as I could (about 3 feet) and turned it several times, fired it up and boom had a full stream and no horn. :nana
You Da Man
Retired OG
#17 Post by Retired OG » Sun May 06, 2018 5:09 am
fredeboy wrote:
Fri May 04, 2018 7:13 am
Well the impeller was replaced mid last season when we swapped this motor on. Only had the boat out 3 times after that due to medical issues. One thing I noticed last night when I started it up was the pee stream was not solid. It would have a little spurt about ever 3 to 4 seconds. Any thoughts on that appreciated. :donno
When you replaced the impeller, did you also replace the other rubber parts??? A few years ago, I had the rubber that holds the water tube on the water pump rupture on the side...it had the same symptoms....I now do the complete rebuild every year. :coffee
#18 Post by bansil » Sun May 06, 2018 8:26 am
Love the trimmer string idea :thumbsup
#19 Post by bansil » Sun May 06, 2018 8:26 am
