First time out, have some problems...
magikat
#1 Post by magikat » Sun Jul 19, 2009 4:59 am
So we took her out. Love the boat, all the room and storage is great. We have some kind of problem with the motor. :( Idles fine and will run slow but try to give it the gas and it bogs out. No take off or power at all. I'm going to check all the lines to see if there is a leak. Was thinking it could be bad fuel, don't know how long it has set up. Any things else you think it could be?
Other then that my dogs had a great time. I got 2 mini doxies and a golden retreivier. My two older dogs have been out on the river many times. The youngest doxie just had a grand time. He took right to the water and the boat. I got to get the problems solved and get us all back out there again.
"Water Hawg"
2006 Starcraft Classic 180
40hp Mercury 4 stroke
bruuuuce
Re: First time out, have some problems...
#2 Post by bruuuuce » Sun Jul 19, 2009 5:41 am
Bad Fuel
Fuel Filter
Dry rotted lines
The primer bulb could be closaping
Plugs
Would be some basic areas I would check
2013 South Bay 442CR STT
150 HP Mercury 4 Stroke
sHan tn
#3 Post by sHan tn » Sun Jul 19, 2009 5:52 am
What bruuuuce said AND
if that dont fix it then the carbs will need to be taken apart and cleaned, my 50 did that and i changed everything and finly cleant the carbs and it run like new :)
DONT let a lil setback discourage you fun.... THATS whats nice about a TOON is ya dont HAVE to go fast to have FUN LOL :)
:dance :drive
1982 Sylvan 24' Toon
50hp Evenruder
my fishin/camping boat
An unarmed man is a subject.
911: Government sponsored Dial-a-Prayer.
When seconds count....Police are minutes away
#4 Post by badmoonrising » Sun Jul 19, 2009 6:36 am
Sounds like a bad accelerator pump in the carb. Rebuild it and you'll be fine.
sHan tn
#5 Post by sHan tn » Sun Jul 19, 2009 2:38 pm
badmoonrising wrote:Sounds like a bad accelerator pump in the carb. Rebuild it and you'll be fine.
HUH??? its a 40 merc
I didnt know they had a acc pump :(
50hp Evenruder
scfishnman
#6 Post by scfishnman » Sun Jul 19, 2009 4:15 pm
Two other possibilities - inadequate venting on the fuel tank (try running with the fuel cap off to see if that helps) or a pinhole size leak in the fuel line allowing air to be sucked in.
-- Yamaha Waverunner FX HO
#7 Post by badmoonrising » Sun Jul 19, 2009 6:59 pm
Nevermind, I'm thinking I/O...wasn't drinking either. :tofunny First thing I'd check though is fuel pressure and go from there.
sHan tn
#8 Post by sHan tn » Sun Jul 19, 2009 7:07 pm
Ok ya had me scraching my head for a min :)
:drink4
50hp Evenruder
Beamer
#9 Post by Beamer » Mon Jul 20, 2009 5:45 am
How about running a can of Sea Foam thru it first, it should help to clean it out and it's cheaper than tearing things apart first.
Had a snowmobile last year that I had not run for two years. Ran like crap when excellerating. added a can of Sea Foam and within a couple hours was running great.
22' AquaPatio 90 4s Yamaha
Port Perry, Canada
tkrein
#10 Post by tkrein » Mon Jul 20, 2009 6:59 am
how old is the gas. if its old dump it and put fresh in if freash check lines and plugs.
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
schmir
#11 Post by schmir » Mon Jul 20, 2009 7:12 am
I like the seafoam idea. I think you might have water in the gas. Another cheap fix is to add a fuel water separator kit to the fuel line. $20 bucks or so.
magikat
#12 Post by magikat » Wed Jul 22, 2009 3:01 am
Great news called the dealer and complained so they are going to fix it. Should get it back before the weekend.
"Water Hawg"
#13 Post by curtiscapk » Wed Jul 22, 2009 6:51 am
Sweet :guitar that's a helluva dealer on a used toon :2cents
