New boat expectations
Posted: Fri Feb 01, 2019 6:23 am
by riplipper
By no means am I a mechanic or expert, but have been around long enough to learn a few things, so I like to try and fix things myself, when possible...
I have had my boat for about 7-8 months now. I use mine both in salt and brackish water.
The very large river by me quite often can get pretty choppy when the wind whips up, actually can get very rough, but I avoid those days.
So the boat gets "challenged" versus smaller smooth lakes.
I have found that many of the screws that hold door hinges as well as other screws, are backing out.
When tightening them up, I find some of them are actually stripped.
Rather than just using one size larger screw to repair, I have through bolted some of them with Teflon locking nuts.
Hauling it back to the dealer to fix these issues just seems ridiculous to me?????? I am sure they would just use a larger screw????
Just curious, does everyone else have these same issues??? BTW, mine is a Harris, which should be a pretty well built boat.
Re: New boat expectations
Posted: Fri Feb 01, 2019 8:01 am
by lakerunner
All my hinges are riveted. I think your fix is the way to go
Posted: Fri Feb 01, 2019 8:04 am
by riplipper
Riveting makes some sense. Didn't even think of that one...and I own two riveting tools. I may try that on the next one for shits and giggles. Thx
Posted: Fri Feb 01, 2019 5:34 pm
by Oldchuck
Rip,
I think high quality stainless bolts with teflon locking nuts would be the way to go. GOOD SOLUTION !!!!
Think I would prefer to rivets....
Posted: Sat Feb 02, 2019 4:06 am
by riplipper
I know the through bolts are a permanent fix. Rivets might look a little prettier.
I may do some of both. Top, center and bottom of door hinge through bolt and ones between those rivet.
Thanks guys.
Posted: Sat Feb 02, 2019 12:17 pm
by ksks
riplipper wrote: ↑Fri Feb 01, 2019 6:23 am
Say it aint so...I have a Harris 210 on order.
Any other problems?
ksks
Posted: Sun Feb 03, 2019 3:45 am
by steve1313
Ask your dealer to come to you to fix these issues. When I got my new boat, a couple of minor issues popped up about a month after delivery. My boat was in a slip an hour and a half from the dealer (they delivered it to me there), and they happily sent a tech to my slip to fix it. He spent three hours driving to spend 30 minutes fixed a couple of things.
I've said it before and I'll say it again............."pick the dealer, then pick the boat!"
Posted: Sun Feb 03, 2019 5:35 am
by riplipper
[/quote]Say it aint so...I have a Harris 210 on order.
Any other problems?
[/quote]
Love my boat, this has really been the only issue boat wise.
My motor drove me crazy, they had the speedo set wrong (mercury)so I ended up buying mercury "vessel view" to
tell me exactly what was going on and that fixed that. Dealer was no help at all.
They switched out the prop, put I wrong hub, I could go on and on about the trouble that was.
Now all is good with motor.
Posted: Sun Feb 03, 2019 5:39 am
by riplipper
steve1313 wrote: ↑Sun Feb 03, 2019 3:45 am
I had a Bennington dealer 3 miles from me but liked some features on the Harris so much more. I picked a dealer 30 miles away.
Horrible decision on my part. But extremely happy now, so a little pain for a couple of months but did get the boat I wanted.
Next time I will choose dealer over boat.....if there ever is a next time.
Posted: Sun Feb 03, 2019 8:09 am
by steve1313
If the dealer is only 30 miles away, I'd definitely have them come to you!
Posted: Mon Feb 04, 2019 10:03 am
by zoom650
Check the screws you think stripped because my Harris uses threaded studs with a binding barrel and you may have lost the barrel on the bottom side. I called my Harris parts guy and they sent me a dozen. They know the exact size you need too.
What came loose on my Solstice had more to do with those holding the bimini hinges. I've since given all the loose ones a touch of Locktite.
It's good to go over your entire boat and check for loose screws.
Posted: Tue Feb 05, 2019 5:55 pm
by bansil
My .02 since I repair/rebuild/modify...just because
Screws into alum tube be it 6061/6063 is a crap shoot, they use small screws to try to get 2 or 3 teeth engagement...that sucks and is B/S.
5 ways to do it is
Weld , but can stress crack
Rivet, but can stretch making them loose
Through bolt with NO spacer to not squish tube which will loosen
Through bolt with spacer, just a pain to position and make...or buy then cut to length to fit inside tubing
Best bet? Rivnuts, spend the $80 for correct tool, buy riv nuts and got to town, make sure to use antisieze for aluminum and different size riv nuts use different install tools...AND DO NOT OVER TIGHTEN you can snap off 1/4-20 SS screws easy
