I suppose not, the engineers that design these boats make way more $$ than I do, down here in the panhandle I just have never seen one with a 20" shaft, and we hang out a lot at our islands with friends, with the floatation of the third log, and knowing how mine will sometimes ventilate with some extra weight in the bow area, I would think a 25" motor would be more adaptable.
Motor height question
- FLOUNDERPOUNDER225
Re: Motor height question
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
Yamaha F-150
The Yamaha SHO 200 and 225HP are still only available in a 20" shaft.
I had the same issue on my boat. 115 Yamaha on 2 log 22 ft G3. Motor was in the bottom hole position. At moderate speed , the water would damn near run up over the front cover. Hard as hell to turn. I raised mine up one hole . What a difference. I called G3 for an explanation. Was told they typically set tri toons in the bottom hole as the increased flotation sets the motor higher in the water. They set two log boats in the middle hole. Mine was set up one hole too low.
Raise it one hole. Its too low, dragging too much water, too hard to turn. Speed will be better too.
Broken Arrow Ok
2014 G3 Suncatcher
115 Yamaha 4 stroke
2014 G3 Suncatcher
115 Yamaha 4 stroke
Soonertoon wrote: ↑Wed Jun 19, 2019 2:02 pmI had the same issue on my boat. 115 Yamaha on 2 log 22 ft G3. Motor was in the bottom hole position. At moderate speed , the water would damn near run up over the front cover. Hard as hell to turn. I raised mine up one hole . What a difference. I called G3 for an explanation. Was told they typically set tri toons in the bottom hole as the increased flotation sets the motor higher in the water. They set two log boats in the middle hole. Mine was set up one hole too low.
Mine's a tritoon which have completely different characteristics than a two log boat. I've never had any issues, my boat runs 40 MPH, which is about all I could expect, turns on a dime, and porpoises before it blows out. I think I'm just going to everything like it is.
I know this post is now about 8 months old, but I just had my dealer perform normal service and they did raise the motor one hole. When they put dropped it off and yesterday it was about 45 degrees so I didn't play with the trim much or make many turns on the way back to my slip so I can't confirm how it will perform. I'll do some more thorough testing soon and let everyone know if there are any significant changes.
