water drain in lower unit??
craigb
#1 Post by craigb » Fri Jul 24, 2009 6:59 pm
i have a 2001 mecury 75. noticed today with water hose ears that there is water coming out of a small hole on backside of motor down by shaft. is that normal?
Re: water drain in lower unit??
#2 Post by lakerunner » Fri Jul 24, 2009 7:06 pm
When running your motor has 2 to 3 places water can exit. The so called Pee hole usually to rear and near the bottom of power head (also known as telltale).
Some have low speed or idle where water comes out of a port about 1/2 down the lower leg and the exhaust hub through prop. When under full power this middle port doesn't spill water under most conditions.
Hope this helps
craigb
#3 Post by craigb » Fri Jul 24, 2009 7:18 pm
that sounds like it. i never noticed before but its a small hole on back beside flat ribbed plates on sides.
bruuuuce
#4 Post by bruuuuce » Sat Jul 25, 2009 7:23 pm
My 97 Force 75 does the same thing.
2013 South Bay 442CR STT
150 HP Mercury 4 Stroke
