Stalling when putting in gear...just filled up with gas
kaptap
#1 Post by kaptap » Sat Jul 25, 2009 10:13 am
I just got our brand new toon about 2-weeks ago and filled it up with gas for the first time. I left the gas pump and within the no wake zone (low rpms) went about 500 yards to our boat slip. While manuvering into our slip, when I put the engine into forward or reverse, the engine stalled. This happened about 6-8 times. I went back into the open water and drove for a couple of minutes and then docked the boat without the engine stalling. Any ideas what may have caused the engine to stall the first go around? Anything I should check?
Perhaps it was that I added new gas but didn't get the RPMs high enough and/or didn't let the engine warm up with the new gas? We were docked at the pump for about 30 minutes, but had been running the engine for an hour or so before filling up. Thanks all for our comments.
EastMark
Re: Stalling when putting in gear...just filled up with gas
#2 Post by EastMark » Sat Jul 25, 2009 10:45 am
I would do anything until I called the dealer if he is open. Its brand new. Some like to blame the victim. ;-)
Mark
#3 Post by lakerunner » Sat Jul 25, 2009 10:52 am
Since we don't what motor you have OB or I/O carbed or injected, 2stk or 4stk it is hard to say.
I suspect you might have been running rich as engine was cold. My Merc is cold natured and tends to run kinda rough until warmed up. Also could be low fuel pressure
kaptap
#4 Post by kaptap » Sat Jul 25, 2009 12:01 pm
My engine is a yamaha 90hp 4-stroke I/O.
Alohatoon1
#5 Post by Alohatoon1 » Sat Jul 25, 2009 1:33 pm
hmmm.....never have seen one of those before.
Please visit my website if you get a chance, better yet submit a couple of your favorite photos there!
The Boating Photo of the Day
#6 Post by badmoonrising » Sat Jul 25, 2009 2:41 pm
Yamaha I/O ? Sure you don't mean outboard ?
kaptap
#7 Post by kaptap » Sat Jul 25, 2009 5:31 pm
I'm a rookie! I meant outboard. Once I learn all these boating terms I'll be better off.
mike
Site Owner
#8 Post by mike » Sat Jul 25, 2009 6:18 pm
Possibly a plugged gas tank vent? Does the bulb remain full of fuel during these problems?
Jimfishes
#9 Post by Jimfishes » Sat Jul 25, 2009 6:21 pm
Yep == I was going to ask about the bulb. Not real hard to get a leak in one. Could be as simple as the factory didn't tighten everything. :givebeer
Jimfishes
2004 Bennington 2575RFS w/150 Yamaha
#10 Post by dockholiday » Sat Jul 25, 2009 8:10 pm
kaptap wrote:I'm a rookie! I meant outboard. Once I learn all these boating terms I'll be better off.
Not a problem, most of these guys been boating for a number of years. Everybody had to learn.........
mikeherb
#11 Post by mikeherb » Sun Jul 26, 2009 7:34 am
Was your motor cold when you left the gas dock?
Could be it is not choking/rich/lean settings when your engine is cold. Have your dealer check it out.
What RPM does your motor idle?
Perhaps the idle speed is not set properly. Again, have your dealer check it out since it's brand new.
kaptap
#12 Post by kaptap » Sun Jul 26, 2009 1:51 pm
Went back tot he boat today and checked the fuel bulb...it was rather soft, so I squeezed it about 10 times and it worked like a champ all day...new owner panic over! Thanks all for your feedback!
#13 Post by lakerunner » Sun Jul 26, 2009 5:14 pm
Dealers love those plastic hose clamps. I recomend everywhere you have a line connection replace with 2per connection SS hose clamps
Heatman
#14 Post by Heatman » Sun Jul 26, 2009 6:29 pm
kaptap nice to hear you got it figured out! Get that 1st season under your belt and you'll be a pro at it.
Loyd, good advice as always. I just replaced the factory gas line and discovered no clamp at all at the tank fitting. It was just pressed up on the barb of the fitting! No wonder the bulb never really felt tight!!
Sheridan, Indiana
tkrein
#15 Post by tkrein » Mon Jul 27, 2009 8:21 pm
Just a ? i have a 75 yammy and never I mean never touched the bulb. what i was told was to turn the key on weight till you here the initial beep then start the motor this gives the fuel pump enough time to pressurize the line. At least that is what my dealer told me the bulb is just there if you were to run the motor out of gas. That is the only time you should ever have to pump it that that is because it is easier on the fuel pump
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
