bigger motor
killerkernrich
bigger motor
#1 Post by killerkernrich » Sat Jul 13, 2019 3:14 pm
Toon will be the same . It has a 60hp 4 stroke if it goes top speed now 18mph what do you think a 90 would get & is a stainless prop worth the $
PLP Member
NRA member
UFC fan
Re: bigger motor
#2 Post by lakerunner » Sat Jul 13, 2019 3:58 pm
I get 21/23 on mine.
Re: bigger motor
#3 Post by bansil » Sat Jul 13, 2019 4:04 pm
Salt water is def. Yes on SS prop, freshwater lake? I wouldn't waste the money, anodized/powder coated alum. Would be fine.
Re: bigger motor
#4 Post by ROLAND » Sun Jul 14, 2019 12:14 am
I've got a 75 on my 20 footer. When it was brand new and the water was smooth as glass, at wide open i got up to 24-25 miles per hour. Last time I checked the speed, probably a year or two ago I was getting 21-22 mph wide open.
wwind3
Re: bigger motor
#5 Post by wwind3 » Sun Jul 14, 2019 3:25 am
I have a 90 Merc Optimax on a 20 ft Lowe fishing model so no couches up front. I hit 30 one day on Sam Rayburn Lake in 2010 when new. but top out at 27 now. Lake Livingston Tx has too many stumps for an aluminum prop so I run a stainless.
Strange side note-I have a spare aluminum prop that is actually faster than the stainless-I hit 28 with it and touched 29 for a minute or so under perfect conditions. Both have 16 inch pitch props. Also I am faster into the wind than downwind--I have underskinning and I suspect I am getting some bow lift into the wind. Pontoon boats are strange creatures--hard to say what you will get.
Also you will be faster in the winter when water is cold and more dense than in summer. Good luck !
2009 LOWE SS204 25in logs
90 Merc Optimax
Motorguide W55 Wireless
Underskinning
28 GPS
boocat
Re: bigger motor
#6 Post by boocat » Sun Jul 14, 2019 6:24 am
Just what little I really don't know much about.. I wouldn't waste $ on SS either. I don't think 90 hp is enough power to flex alum. And I would much rather trash an alum prop that a shaft. The mechanic at the dealer where I bought the boat actually recommended against SS. I think they have their place but also think that in alot of cases guys just want to think they have something special.
killerkernrich
Re: bigger motor
#7 Post by killerkernrich » Sun Jul 14, 2019 2:43 pm
mine is a 22ft fish model with just me no wind 60hp 4stroke mercury 10 yrs old runs good 18 tops just wondering what a new 90hp might get me?
PLP Member
NRA member
UFC fan
wwind3
Re: bigger motor
#8 Post by wwind3 » Sun Jul 14, 2019 6:36 pm
I'm thinking 23-24
90 Merc Optimax
Underskinning
28 GPS
410MAN
Re: bigger motor
#9 Post by 410MAN » Mon Jul 15, 2019 9:27 am
I just sold 22 ft G3 toon ,90HP 4stroke yamaha 22-23 max with 2 peeps.
BobL
Re: bigger motor
#10 Post by BobL » Mon Jul 15, 2019 10:08 am
….10 yrs old runs good....
While I love to spend other people's money, I personally wouldn't until your current motor takes a crap and you have to spend it. Personally, I don't see gains substantial enough to offset the cost.
steve1313
Re: bigger motor
#11 Post by steve1313 » Mon Jul 15, 2019 10:53 am
………………….. in alot of cases guys just want to think they have something special.
Yep, I've a "special" stainless steel prop. The special part is that it's attached to a cool pontoon boat! :biggrin2
Marc K
Re: bigger motor
#12 Post by Marc K » Mon Jul 15, 2019 11:20 am
Yep - This would be my opinion also. Assuming a new top speed of around 22-23 MPH, the gain would not justify the cost for ME. It might be totally different for you!
Remember that you will also see a 50% increase in fuel consumption per hour, when comparing the two motors running wide open. That may impact your fuel tank sizing, depending on what you have now.
The flip side of that is that the same 18 MPH with the 90 will mean a lower cruising RPM than your 60 running wide open. My boat sucks up close to 10 GPH wide open and only half of that at 4200 RPM. So, in my case I double my fuel consumption to go from 18-19 MPH to 24-25 MPH under identical conditions. Take a guess where I cruise if I'm going a long distance and want to make my 24 gallons last? :biggrin2
killerkernrich
Re: bigger motor
#13 Post by killerkernrich » Sun Jul 21, 2019 8:45 am
Thanks to every body for your thoughts I can live with what I got. the 60hp does real good on gas as I mostly troll at 2 to 3 mph.
PLP Member
NRA member
UFC fan
