Legacy Graphics. Sylvan/Smokercraft
Posted: Thu May 28, 2020 12:32 pm
by brian baldridge
Does any one have a source or trick to reproduce the graphics on the siding of my 2002 Smokercraft 818 4-Point? If not, has anyone had success removing and re-using the original vinyl graphics? I bought my boat in September with two sections of damaged/wrinkled ribbed aluminum siding. I replaced the aluminum, (it wasn't easy) but need graphics.
Desperate in Chico, CA
The replaced panels are on the starboard side thus cannot be seen in this picture, but graphic "waves" and lower speed stripes seen behind the "Smokercraft" is what I am needing to replace.
Re: Legacy Graphics. Sylvan/Smokercraft
Posted: Fri May 29, 2020 7:42 pm
by Rick McC.
Graphics and “wrap” businesses should be able to reproduce and install those graphics pretty easily. mOr; you could just contact the OEM.
Posted: Fri Jun 05, 2020 2:58 pm
by brian baldridge
Thanks Rick. I tried OEM Sylvan/Smokercraft but they work through dealers. I reached out to a couple Sylvan of dealers in California but no joy.
Posted: Sat Jun 06, 2020 4:12 am
by steve1313
Take a fairly close up picture of what's on the boat now that you want to match. Measure the length and height.. Take it to any "fast signs" place and they should be able to easily match the font, or come so close you won't even know unless the new was side by side with the old. They should be able to do the same with the graphics.
