Water Pump Impeller
Posted: Thu Aug 27, 2020 3:33 pm
by Capt Sully
I have a 90hp Yamaha and when I start it the water doesn't flow out. It's been sitting for a year and has 36hrs on the motor. Do you think the rubber water impeller has broken apart ? The impeller is in the lower shaft, I think ??
Re: Water Pump Impeller
Posted: Thu Aug 27, 2020 5:05 pm
by Marc K
First try cleaning the proof tubing path, starting at the outlet end.
Mine sat for 3-1/2 years and the impeller was a little stiff but still fully functional. I highly doubt that the impeller disintegrated so badly that you get zero flow in that time frame. I used a piece of weed eater line and a touch of carb cleaner to ream it out a bit. Once I got a little bit flow, it took off.
Posted: Thu Aug 27, 2020 6:04 pm
by Capt Sully
Thanks Marc.....I'm going to remove the inlet plates and take a look...
Posted: Thu Aug 27, 2020 11:12 pm
Dirt dobbers love to fill up the pee hole.
If you're the original owner and you haven't run the engine without water, the chances of you needing a new impeller is nil. Yamaha impellers are really tough and long lasting.
Sometimes it takes a 30 seconds or longer for the water to flow out of the hole.
Posted: Fri Aug 28, 2020 3:10 am
by boocat
Bamaman wrote: ↑Thu Aug 27, 2020 11:12 pm
sounds like a long time.
Posted: Fri Aug 28, 2020 3:34 am
by Steiner
Kinda what I was thinking. He's from GA and I am too....those things don't waste any time. Gotta be careful taking a crap outdoors because those things will plug your b-hole before you can get your pants up.
Posted: Fri Aug 28, 2020 6:23 am
by curtiscapk
Mud dobbers! I have this in my tool compartment! Weed eater string long enough to run the whole tube.
Posted: Fri Aug 28, 2020 2:50 pm
by RJFisher
On my Honda the hose came off the fitting.
