Transducer mounting
Kytim
Transducer mounting
#1 Post by Kytim » Mon Jan 11, 2021 3:11 pm
My wife(man I love her) purchased me a new lowrance (Hook reveal 7 triple shot)for Christmas
Anyway I'm going to mount it on our pontoon.
In the past on other boats I mounted the transducer inside the hull using epoxy ,these were all fiberglass boats.
My pontoon has the usual mounting bracket on the end of the toon.To keep the transducer from being torn off I was hoping to mount it inside the bracket using epoxy
Has anyone tried this and will the transducer work thru aluminum
2019 Tracker 22 DlX sportfish
115 Mercury Command thrust
A Day hemmed in prayer seldom comes unraveled .
jediger
Re: Transducer mounting
#2 Post by jediger » Mon Jan 11, 2021 9:19 pm
Seems like overkill. Did your unit come with a through hull transducer or were you planning on buying another one?
For point of reference, I have a transducer on the back of each toon and they never give me an issue.
Pinawa Bay, Manitoba
Kytim
#3 Post by Kytim » Wed Jan 13, 2021 1:46 pm
Mine doesn't have the thru hull > I was going to buy one.My concern is that my swim ladder comes off back of toon on the same side as the transducer and i was afraid the
grand kids wear tear if off climb on/off the boat
jediger
#4 Post by jediger » Thu Jan 14, 2021 7:50 am
Cheaper to train the grandkids. And if they wreck it, replace the transducer. You were going to buy a new transducer anyway...
#5 Post by lakerunner » Thu Jan 14, 2021 9:53 am
You need the transducer below the bottom of the log, Otherwise lots of interference from turbulence.
jediger
#6 Post by jediger » Thu Jan 14, 2021 11:25 am
Thornback
#7 Post by Thornback » Sun Jan 17, 2021 7:40 am
On my 2021 Bass Buggy 16 I mounted the transducer for my Humminbird on the bracket supporting my live well pump that is located on the rear of the port pontoon. Drilled two holes in the aluminum bracket and used the Humminbird mount. Works just fine, no prop interference, and gives depth reading even at top speed, 23 MPH.
#8 Post by Bamaman » Sun Jan 17, 2021 1:12 pm
I found my OEM transducer just hanging by the wire, and I assume I hit a log sometime.
Went to Amazon and ordered another transducer. The manufacturer had the original wiring attached to the toons and crossbars. So I had to order an extension cable so my cord would reach halfway the length of my boat and all the way across to the driver's console.
Fortunately, I had a Harbot Freight fiberglass wiring snake used to pull the cable without having to remove any aluminum sheets underneath the boat.
Transducers must be left where there is no metal under them, and they cannot be placed inside any metal hull.
riplipper
#9 Post by riplipper » Tue Jan 19, 2021 6:03 am
I moved my transducer to the other toon to keep it away from the ladder. Very easy to do on a pontoon boat, as long as your port tune has a bracket for it.
