Hydrus props
fishmor
Hydrus props
#1 Post by fishmor » Sun Aug 23, 2009 3:20 pm
What's the take on the Evinrude Hydrus props? My use would be pontoon boats.
Re: Hydrus props
#2 Post by HandymanHerb » Sun Aug 23, 2009 3:50 pm
Looks like there made for pontoon, we don't what size engine your putting it on but looks to be a good one.
HYDRUS Props:
Bites the water and stays on tight.
3 blade prop. For pontoon and work boats. Aggressive cupping - excellent gripping, that holds tight in turns with maximum thrust in all water conditions. Big blade area works well in high reverse thrust.
New Hydrus Propeller Exhaust Ring: Part Number #50006512.
Improves midrange engine operation and performance on Evinrude E-TEC 40, 50, 60, 75 and 90 hp engines. The Hydrus propeller exhaust ring should be used on gearcases fitted with Hydrus propellers Part Numbers: 177201, 177202 and 177203.
fishmor
Re: Hydrus props
#3 Post by fishmor » Tue Aug 25, 2009 11:59 am
Thanks
