I'm sure it really depends on the thickness of the aluminum though. It seem some manufactures sell toons with 3.5lb of pressure in there toobs . On a really hot day sitting out of the water, that would have to push the pressure well past 5lb psi.A lot of them here do have a schrader valve in them on the top some place . With a drain plug on the top, near the back . This has a pipe in it that goes down to the bottom of the log. So any water in the log blows out when you put air in it.
Im with GregH here for sure . Had a friend put a air compressor on his to check it out. Poped open a seam at the bow with about just 5 lb psi. If you go that way try a air hand pump.
Dont forget there always is good old 3M 5200
2009 Berkshire Pontoon Boats 201FC Standard Features
Colors Choices
• Cabernet
• Forest Green
• Graphite
• Navy Blue
Standard Features
• 3 Year Stem to Stern Warranty
• Limited Lifetime Chassis Warranty
• Limited Lifetime Deck Component Warranty
• 3.5 psi Air Pressurized & Chambered Pontoons
• Full Length Protective Bottom Keel
• Boca Raton Carpet
• Tachometer
• Voltmeter
• Fuel Gauge
