Not a fun evening on the lake...
pcryer
#1 Post by pcryer » Mon Mar 29, 2010 6:15 pm
Thought we would go out after work and make sure the boat was up and running for the upcoming season. Every thing was going smooth and boat was running great! Very few people on the lake, not too hot, not too cold. Get out in the middle of the lake and out of nowhere the motor slips out of gear :donno Not a good feeling at all. We had one boater approach and apologize but he was only on the water for about an hour and wanted to get in some fishing :cry: Fortunately the next boaters where very helpful and even towed us across the lake and then helped us get the boat on the trailer :nana So we are now home and wondering what has gone wrong and how much this is gonna cost us :scared Any suggestions/hints/tricks/tips/matches?
2013 Xcursion X19F
2013 Yamaha F70
2006 Ford F250
2006 Coachmen 2600 Motorhome
1 Canoe
3 Yaks
trott46
Re: Not a fun evening on the lake...
#2 Post by trott46 » Mon Mar 29, 2010 6:27 pm
Just a though and could be a cheap fix check the hub make sure its not spun put motor in gear and spin the prop if it spis and the prop nut doesn't then thats the culprit
115 mercury
Tri-Toon with Strakes
2004 F-250 Powerstroke
pcryer
#3 Post by pcryer » Mon Mar 29, 2010 7:57 pm
trott46 - Just checked it and unfortunately the nut spins. Any other suggestions?
2013 Xcursion X19F
2013 Yamaha F70
2006 Ford F250
1 Canoe
3 Yaks
trott46
#4 Post by trott46 » Mon Mar 29, 2010 8:29 pm
what year size and brand of motor and i will check to see if i can get the manual and get you in the right direction
115 mercury
pcryer
#5 Post by pcryer » Mon Mar 29, 2010 8:37 pm
Sorry, I should have included that information. We have a 2002 Bennington 2275 FS with a 2003 Mercury 150 XR6.
2013 Xcursion X19F
2013 Yamaha F70
2006 Ford F250
1 Canoe
3 Yaks
FloterBoter
#6 Post by FloterBoter » Mon Mar 29, 2010 8:58 pm
don't know that specific motor but the first thing i'd check would be the shift cable adjustment.
jimrs
#7 Post by jimrs » Mon Mar 29, 2010 9:02 pm
Your explanation was not the best to figure out anything. The motor slipped out of gear? How fast were you going, or rpm? Did the motor RPM race out of control until you pulled back the throttle? We need a little more infomation to really be able to help you. Try and explain the entire event even if it takes a couple of paragraphs.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
trott46
#8 Post by trott46 » Mon Mar 29, 2010 9:02 pm
I dont see the manual the next thing i would do is locate the shift rod just above the cavitation plate on the boat side of the motor and have someone put it in gear while you watch it to see if it turns if so then it is in the gearing in the lower unit if it does got then it should be in the cable or linkage
115 mercury
FloterBoter
#9 Post by FloterBoter » Mon Mar 29, 2010 9:27 pm
pcryer wrote:We had one boater approach and apologize but he was only on the water for about an hour and wanted to get in some fishing.
federal law required him to render assistance if able to do so without seriously endangering the vessel or crew, 46 USC Sec. 2304.
your state law probably provides the same. had your not fun evening turned deadly, he could've been fined not more than $1,000,
imprisoned for not more than 2 years, or both.
h2otoo
#10 Post by h2otoo » Tue Mar 30, 2010 5:01 am
Not to mention the guy had to be a real shiphead!
Bob
Little Boat, Little Lake, Big Smile!
pcryer
#11 Post by pcryer » Tue Mar 30, 2010 5:33 am
We kinda thought there was a law but fortunate for us the other people came along. I am sure the first guy will have his day some day.
To explain the situation a little better: We were running about 36-38 mph and playing with the trim trying to get that sweet spot for the most speed. The motor slipped out of gear but continue reving up. We could kill the motor and start it back up with no problem, it just would not go into gear. When we got home and starting trying to figure this out it seemed kinda stiff to push the throttle forward into gear but the prop never did engage. When the prop is spun by hand it spins freely but does make a clicking noise.
Sorry if this is not the best explaination but I am by no means a writter :biggrin2
Thanks again!
2013 Xcursion X19F
2013 Yamaha F70
2006 Ford F250
1 Canoe
3 Yaks
#12 Post by HandymanHerb » Tue Mar 30, 2010 6:47 am
Been years ago on an older Evinrude on a 15 runabout, I came through the one weed bed to go from one lake to the other and you alway stopped on the other side and reverse the prop to clear the weeds from the prop.
Worked great the 30 times before we did it and one day after I cleared the prop I had no gears and was dead in the water, it that case it was a carter pin that rusted apart and let the shift rod go
oldmn19
#13 Post by oldmn19 » Tue Mar 30, 2010 7:03 am
Did you try shifting into reverse while on the water and if so what happened? If you didn't have reverse either you may have lost the lower end! If you had reverse it may just be the shift cable adjustment, I hope that's what it is for your wallet!
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
BassFrequency
#14 Post by BassFrequency » Tue Mar 30, 2010 7:45 am
i had a shift problem a while back only my throttle got stuck in forward (toyota syndrome) :rofl lucky for me i hadnt left the dock yet and was just priming the motor. turned out the plastic cam in the throttle box had broke up and jammed.
60HP Evinrude
WaltF
#15 Post by WaltF » Tue Mar 30, 2010 8:56 am
Sounds like your throttle linkage got outta wack or hosed up.... :donno
That would be the first thing i would check...
Colorado Springs, CO.
