Water pump to mount on pontoon?
Posted: Sun Jul 22, 2007 8:46 am
by lakejumper
Hi folks,
I'm new to pontoon boats and to this site. It's a great forum! I just purchased the boat in my signature and I'm looking for a pump that I can mount to the rear of the portside pontoon to use for pumping raw water for a live baitwell and to use for washdown. The boat has the livewell tank but no pumps. There is a mounting bracket with 3 holes already on the pontoon. I've done searches on the internet and can't find what I am looking for. I have contacted Godfrey Marine and the local dealer and no one has gotten back to me. Any suggestions on what brands to look for would be greatly appreciated.
Thanks,
Lakejumper
Posted: Mon Jul 23, 2007 6:23 am
by mike
I think my livewell pump is made by sureflo...
Check it out
HERE
Sorry
Posted: Mon Jul 23, 2007 12:05 pm
by fishmor
A bilge pump which is also used to supply water for bait tanks doesn't put out enough water or pressure for wash down. What you are looking for to pump water to your bait tank is a bilge pump. I don't know how large your bait tank is or how much over flow it has but you would probably be well served with a 500 gal an hour pump. If you get one that is too large the tank can't drain fast enough to keep it from over flowing. Wash down pumps cost lots more and put out a lot more water and pressure.
Posted: Mon Jul 23, 2007 7:45 pm
by Toontroller
Mine had a 500 gph bilge pump as fishmore said. The pump sat on a angle bracket and holds were drilled through the mount an into the bottom of the pump and pop riveted in place w/ two rivets. It's a very simple install.
Posted: Wed Jul 25, 2007 9:32 pm
by lakejumper
Thanks for your responses. It looks like the bilge pump will do the job for the livewell and I will install a Shurflo pump for the wash down.
Posted: Fri Aug 17, 2007 6:40 am
by Fritz
I believe your live well pump mounts under the seat next to the seat where your livewell is. If you look in your battery compartment you can see a big empty space under that seat.
Posted: Fri Aug 17, 2007 7:48 am
by lakejumper
Thanks, Fritz. That's where I will put it.
Posted: Mon Sep 03, 2007 4:59 pm
by lakejumper
I ended up purchasing a Shurflo raw water wash down pump kit that comes with a garden type of hose and fittings. I purchased a 6 gallon water tank and fittings so that I can use fresh water instead of lake water. I am mounting it under the console and running 3/4" with 1/2" inside diameter hose to the front and rear of the boat. I have garden hose fittings to put on the ends so I can attach a coiled hose and sprayer. Now the only problem I am having is what to connect the power for the pump to under the dash. I have two rocker panel (Contura style) switches that I don't think are being used, one for an "Aerator" and another for "Accessory". Does anyone know what wires go to each terminal? I think that it has 6 terminals on the switch. There are wire harnesses already attached to each switch. I'm going to call the dealer tomorrow to see if they can walk me through it.
Posted: Wed Sep 05, 2007 5:08 am
by Fritz
Look at how the stereo switch is wired and hook it up the same as that is what I would do.
