are toons foam filled on a 93 suntracker
Posted: Thu Apr 22, 2010 6:28 pm
by hotairgypsy
when did suntracker start foam filling the toons. I am looking at a 93 sun tracker and am wondering if the toons are filled
Re: are toons foam filled on a 93 suntracker
Posted: Thu Apr 22, 2010 6:36 pm
by dockholiday
Not sure if they are foam filled but if you tap on the wall with something like a wad of keys should be able to tell, mine really echo, might be the larger tubes. Don't remember the old toon being that loud or hollow sounding.
Posted: Thu Apr 22, 2010 6:38 pm
by HandymanHerb
I think it was just u-tubes that were foam filled
Posted: Thu Apr 22, 2010 6:40 pm
by toondog
I think it was mainly the U shaped logs that were foam filled. I had an 89 tracker that did not have any foam.
Posted: Thu Apr 22, 2010 6:55 pm
by lakerunner
If there is fom it was put in by someone besides tracker. They only use air chambers
Posted: Thu Apr 22, 2010 7:08 pm
by hotairgypsy
what is a u shaped....
is this a u shaped???
Posted: Thu Apr 22, 2010 7:14 pm
by badmoonrising
No...
U shaped logs are like the ones G3 uses.
Posted: Thu Apr 22, 2010 10:24 pm
by HandymanHerb
There more like canoes with a deck on them, open top, the foam stopped them from sinking, we have trapped air in many chambers
Posted: Fri Apr 23, 2010 9:53 am
by WaltF
hotairgypsy wrote:what is a u shaped....
No, thats something completely different, called TRASHED.... snicker..
U shaped toon example..
Round on the bottom, flat on top..
Posted: Sat Apr 24, 2010 11:12 pm
by curtiscapk
What the fuck happened to that toon!!! Looks like the Floater but worse!1
No foam!
Posted: Sun Apr 25, 2010 7:31 am
by toondog
No, that's called U smaurt.
U over insure your old boat.
U park it in a trailer park.
U wait for the next tornado.
U buy new boat.
U smaurt.
Posted: Sun Apr 25, 2010 11:09 am
by Olustee bus
My 2000 suntracker does not have foam.
Would it be advisable to add foam if they ever leak?
Posted: Sun Apr 25, 2010 11:59 am
by HandymanHerb
Olustee bus wrote:My 2000 suntracker does not have foam.
Just get the leak welded, our pontoon use trapped air to stop a pontoon from sinking even if you punch a big hole in it.
