twisting deck while running problem
BassFrequency
#1 Post by BassFrequency » Tue Apr 27, 2010 3:22 pm
i noticed over uneven chop, my front half of the deck looks like its twisting a bit. whether its supposed do that or not its uncomfortable to watch it do that so whats the best way to correct this? i was thinking of adding alum C channel but i would like to know if anyone else had any other soulutions. i just know its killing my speed when its flexing but i for sure dont want anything to break off in the middle of the lake crossing an inconsiderate dillweed cruisers wake :shock:
and no stereo vibration/bolts loose jokes :rofl :rofl :rofl :rofl unfortunatly ive already checked that :cry:
60HP Evinrude
toondog
Re: twisting deck while running problem
#2 Post by toondog » Tue Apr 27, 2010 3:59 pm
It will depend on how heavily built your boat is. Mine is built for a max 70 hp motor so it is built on the light side. I have always had some flexing going through the chops at speed. I started to notice it getting worse, but didn't think anything of it. One day while on my float, I floated under the boat (that's one thing I love about two loggers :biggrin2 )I noticed I had a "M" bracket on both sides with cracks where the deck bolted on. Had them welded and I am back to slightly flexing. Just something to check.
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
BassFrequency
#3 Post by BassFrequency » Tue Apr 27, 2010 4:25 pm
toondog wrote:It will depend on how heavily built your boat is. Mine is built for a max 70 hp motor so it is built on the light side. I have always had some flexing going through the chops at speed. I started to notice it getting worse, but didn't think anything of it. One day while on my float, I floated under the boat (that's one thing I love about two loggers :biggrin2 )I noticed I had a "M" bracket on both sides with cracks where the deck bolted on. Had them welded and I am back to slightly flexing. Just something to check.
x members are on 24" centers in the fronts and go to 12" centers in the back. I'll inspect the M brackets in the mornin. I probably should mention shes rated for a 120hp and the original x members are S channel not C
60HP Evinrude
#4 Post by lakerunner » Tue Apr 27, 2010 5:02 pm
If there is room I would add a 2x2x1/4" aluminum angle all the way across and bolted to cross members and logs. I had a saggy transom ( no old jokes) and thats how I fixed it. The boat is 16 years old and when new owner(6yr ago) took it to Sundancer for refurbish they told him it was a hell of a strong support and left it on.
Bamby
#5 Post by Bamby » Tue Apr 27, 2010 6:10 pm
While you're looking at the brackets, etc. also carefully check out the condition of the plywood floor decking while your at it. Pontoon boats rely heavily upon the deck as a key structural element in their overall stability and structural rigidity. If your plywood is starting to "fail" it could also allow the flexing to take place your speaking of.
BassFrequency
#6 Post by BassFrequency » Tue Apr 27, 2010 7:23 pm
Bamby wrote:If your plywood is starting to "fail" it could also allow the flexing to take place your speaking of.
thats what i didnt really want to hear :cry: :cry: thats a job i dont have time or $$$ for at the moment. the ply wood doesnt have any bad spots in it yet that ive found so hopefully its not that. if its a bad bracket or needs alum reinforcment i can weld that up fairly easily
60HP Evinrude
WaltF
#7 Post by WaltF » Wed Apr 28, 2010 9:09 am
When in doubt, WELD THAT SUCKER!! :nana :nana :nana
well, that n duct tape.. :smoke
Colorado Springs, CO.
GXPWeasel
#8 Post by GXPWeasel » Wed Apr 28, 2010 9:56 am
I have never noticed any flex in mine at all, even on really choppy days, and is only rated for 125hp. max. I wonder if the floor being made of aluminum helps with the structrual regitity?
Hopefully you can get it all figured out there BF. Sounds like guys here have noted a few good options for you.
Bamby
#9 Post by Bamby » Wed May 05, 2010 5:35 am
Bump, have you located whatever ailing it? Hopefully it is or was something simple and easy and inexpensive to fix.
BassFrequency
#10 Post by BassFrequency » Wed May 05, 2010 6:26 am
went swimmin yesturday and found some cracked welds on the back M brackets which may or may not be leaking, havnt found proof either way yet. but i think i'll lower my center log so its even with the bottom of the outer logs as i noticed when the bow is on plane, not much of the center log is in the water and the outer logs seem to be carrying the extra weight.
60HP Evinrude
#11 Post by curtiscapk » Wed May 05, 2010 6:33 am
Swimming???? WTF its 63 degree water you sir are :drink4 :hairpull :? :shock:
BassFrequency
#12 Post by BassFrequency » Wed May 05, 2010 8:04 am
curtiscapk wrote:Swimming???? WTF its 63 degree water you sir are :drink4 :hairpull :? :shock:
2 words :biggrin2 Polar Bear :rofl :rofl :rofl
60HP Evinrude
GXPWeasel
#13 Post by GXPWeasel » Wed May 05, 2010 10:50 am
That's warm enough. Hell a couple weeks ago, I was swimming in 50* water.
Glad you may have found the culprit BF. Good luck on getting her fixed up.
#14 Post by curtiscapk » Wed May 05, 2010 11:05 am
Godddamn Jayhawk for ya!! :rofl :rofl
GXPWeasel
#15 Post by GXPWeasel » Wed May 05, 2010 12:07 pm
curtiscapk wrote:Godddamn Jayhawk for ya!! :rofl :rofl
Hey hey hey, no Gheyhawker here. Wildcat all the way ( not a Tiger either ) :eviltaunt
