aluminum prop repair?
Posted: Sun May 02, 2010 6:32 pm
by wed
I got outside the boat lane today and managed to run over a sumberged object. Bent the amuminuim prop, limped back to camp and pulled it off. Put the boat on the lift backwards to pull prop so that was easy enough. I am going to buy a stainless steel unit but I am thinking about taking the aluminum prop to the shop to see if they can repair it. Anyone out there have any experience with prop repair?
Re: aluminum prop repair?
Posted: Sun May 02, 2010 9:03 pm
by HandymanHerb
If you have a prop shop use them, I bought a new SS one and it was still a little off on pitch, he repitched, put a cup in it for me and repaired my old one too.
Posted: Sun May 02, 2010 9:07 pm
by dockholiday
Think most good prop shops can do the rebuild, they might even have what you want in a ss. Places like that accumulate thing over the years.
Posted: Sun May 02, 2010 9:09 pm
by lakerunner
Our local rebuilds alum props for $50.00 and it looks like a new one
Posted: Sun May 02, 2010 11:04 pm
by wed
OK, I will check out the local prop shop.
Thanks!
Posted: Mon May 03, 2010 11:43 am
by wed
Thanks again guys, Prop Shop says $40 and ready by the end of the week. I will posts again when I have had a chance to run it and see if it gives the same performance.
Posted: Mon May 03, 2010 10:51 pm
by FloterBoter
usually $35 to $40 here to fix aluminum.
as to a stainless steel prop...
"hit with aluminum, break the prop.
hit with ss, break the gears."
your call.
Posted: Tue May 04, 2010 10:17 am
by jimrs
Not so true! I have hit my ss prop on stumps on 5 different boats and have never damaged the lower unit, and did very little if any damage to the ss prop.
Posted: Wed May 05, 2010 9:26 am
by WaltF
So far so good Jimrs!
bet that trick wouldnt work as well on a rock though.... heh
Course with less then 150hp, why spend the money on a ss prop? The main advantage of ss is it wont 'flex' when ya run the big horses into it...
ss prop $600
al prop $95
Posted: Wed May 05, 2010 10:53 am
by dockholiday
ss prop $600
al prop $95[/quote]
agree 100 percent............you just don't get much return on your investment....
t
