drilling through carpet
Posted: Sat May 08, 2010 4:47 am
by leon phelps
hello,
I have a 20' pontoon that I recently re-decked and put new carpet on. I would like to drill through the carpet to install the sides. The sides are screwed down with lag screws. I would like to pre drill for the screws.
Should I take any precautions before drilling in the carpet?
Re: drilling through carpet
Posted: Sat May 08, 2010 6:26 am
by lakerunner
Depends on carpet. Some will grab the bit and frey the carpet and some won't I would try a scrap piece to see first. Might be able to use a solder gun or hot bolt to melt where hole is going.
Re: drilling throuigh carpet
Posted: Sat May 08, 2010 7:48 am
by jimrs
I always cut a small slit where I am going to drill. There is nothing worse than unraveling the carpet with a drill bit. It can spread all the way across the carpet to the end pulling up one strand can be seen from outer space.
Posted: Sat May 08, 2010 8:13 am
by hotairgypsy
old trick is drill backwards first then flip the switch to drill normal never lifting
Posted: Sat May 08, 2010 8:26 am
by leon phelps
I think I will try the hot tip trick. Maybe find a junk drill bit and heat is red hot then touch it to the carpet.
Posted: Sat May 08, 2010 9:10 am
by dockholiday
think i would use a punch an reverse drill then go forward.
Posted: Sat May 08, 2010 9:58 am
by toondog
hotairgypsy wrote:old trick is drill backwards first then flip the switch to drill normal never lifting
ditto
Posted: Sun May 09, 2010 4:08 am
by onthelaketwo
some of the other suggestions are good
Also if you have a hand drill, use that. You control the speed and can monitor the carpet.
Worked for me.
Posted: Sun May 09, 2010 6:09 am
by toondog
Drilling in reverse is also a good technique for fiberglass/gel coats.
Posted: Sun May 09, 2010 8:10 am
by tkrein
awsome info didnt know how to drill through the carpet but the owners manual says becareful as the carpet is one string and drilling may ruin the carpet
Posted: Wed May 12, 2010 12:51 am
by FloterBoter
i wouldn't do it. i'd slit it and insert a bushing, then drill through that.
