Aftermarket lifting strakes and tritunes
Do any of you know any companies that make aftermarket lifting strakes that i can weld on and also any aftermarket tritunes. i have a 27' Suntracker with a 3.0 mercruiser I/O. I want itto lift up out of the water instead of just plowing water..
27' Suntracker Party Barge 3.0 Mercruiser I/O, 8 6x9 jl audio speakers with 2 1,000watt amps, 2 12" jl audio subs, Boat has full bar on it, polished tunes, led lights, etc
Re: Aftermarket lifting strakes and tritunes
Welcome. I'm not aware of any, but Tracker's warranty states that you cannot modify or weld the logs or the warranty is void. I would contact your dealer. One product to avoid completely is Tap Fins.
The boat is out of warranty. I just want it to go faster... thanks for any help
Your RPM at top speed should be around 4400, if you aren't right about there you may wanna consider a prop change. A 27 ft. 'toon with a 3.0 would max out at about 19-20 mph tops. Any difference in top speed if you adjust the tilt while underway ?
I asked the BassPro doode about this once because I was hoping if i got THEM to do it, the warranty would remain in affect.
He said 'Nope', they wouldnt do it...
Colorado Springs, CO.
What you need to do is have a welding shop make it for you.
Goofy can duct tape some on for ya
