2004 Tracker 32 gal gas.
#1 Post by lakerunner » Wed May 12, 2010 10:38 am
My built in gas tank has been giving me fits. For over a year I have fought to keep my fuel line in prime. I blamed it on adding fuel water separator. Replaced fuel lines twice, primmer bulbs also a few times and still had problems.
Well I decided I must have an obstruction in gas take pick up so I removed gas lines and using compressor blow tip shot some air into the connector where I clamp fuel line.
BINGO I found the culprit, The connector has a check valve inside it and it was sticking. It would let fuel through then stick. I took the POS off and replaced with a connector without check valve. 3 pumps and ball is hard and stays that way.
So be aware of that if you ever have the same issues.
Re: 2004 Tracker 32 gal gas.
#2 Post by badmoonrising » Wed May 12, 2010 5:38 pm
Are you talking about the aluminum connector on the tank ? If so, that's very common. The on-tank check valve on my old Proline did the same thing once. It seems Moeller tanks have issues with bad check valves.
#3 Post by lakerunner » Wed May 12, 2010 6:31 pm
Thats it Ed, I never thought to look there before
GreenGolfBall
#4 Post by GreenGolfBall » Thu May 13, 2010 7:11 am
could that cause the engine not to hit the proper RPM's?
#5 Post by lakerunner » Thu May 13, 2010 9:16 am
I don't know for sure but I would try it before carb work
#6 Post by badmoonrising » Thu May 13, 2010 9:20 am
Sometimes when they start to go bad they make a little noise. Hard to explain, but you shouldn't hear anything normally. If you have a portable tank, hook it up to the motor and run it. If it runs better, the valve could be bad or a restriction in the line itself.
Parasympathetic
#7 Post by Parasympathetic » Fri May 14, 2010 7:10 am
lakerunner wrote: 3 pumps and ball is hard and stays that way.
Mine used to do that. :devillol
2015 Ranger RT175
Yamaha 70hp
Lake Wappapello, MO
WaltF
#8 Post by WaltF » Fri May 14, 2010 8:22 am
I knew that one couldnt be pass up... :rofl
Colorado Springs, CO.
GXPWeasel
#9 Post by GXPWeasel » Fri May 14, 2010 2:25 pm
shit, I can't even make 3 pumps. Somehow, I got the name "2 pump chump" :happy :alright
