ss prop
Posted: Tue Jun 01, 2010 8:06 pm
by jim454
I'm in the market for a honda 50hp prop, thinking of stainless steel.
I thought there was a thread on this in the past but couldn't find it.
Your wisdom is appreciated.
Re: ss prop
Posted: Tue Jun 01, 2010 8:14 pm
by jim454
Re: ss prop
Posted: Tue Jun 01, 2010 9:10 pm
by pontoon shine
Hi, I have a 50 honda and run a 12.25 x 9 aluminum and can only get 4700 rpm and 19 mph gps. I have changed the tach and still get same results. Have tried four blade and three bladed props with less rpm results. I actually lost almost half a blade on prop this past weekend and just ordered a piranha prop. What are you other 50 hp honda guys using and what kind of speed and rpms do you get.
Neal
Re: ss prop
Posted: Wed Jun 02, 2010 4:56 am
by jim454
Seems to me I was getting 5000 rpm's and 17 mph (gps) with mine. I'll hopefully confirm that this weekend.
Re: ss prop
Posted: Wed Jun 02, 2010 7:51 am
by slingshot
Other than looking pretty, putting a SS prop on you 50 is not going to get you any better performance than a aluminum. You see, an aluminum prop will “flatten out” when placed under load. Thus, an aluminum prop that has a pitch of 13 will flatten out to say a 12.5 under wot. SS props on the other hand don’t flatten at all under load thus, you get better hole shots and top end. The load from a 50 HP motor simply isn’t enough to flatten a aluminum prop at wot so your performance won’t really improve. Usually the 90 hp motors and above are the motors that enjoy a performance boost from a SS prop.
Re: ss prop
Posted: Wed Jun 02, 2010 11:44 am
by WaltF
Ya, with a 50 hp motor, just stick with an Aluminum prop.
I wouldnt worry about going SS until at 150hp or more...
Also..
SS Prop -> $600
Aluminum Prop -> $100
Nuff said.. :smoke
Re: ss prop
Posted: Wed Jun 02, 2010 2:53 pm
by wed
Aluminum pops will not transmit as much shock into the motor as a SS prop. If you hit something hard the aluminum will bend where the SS wont, might save some wear and tear on the lower unit and power head. You can buy a second aluminum prop, prop nut kit and floating prop wrench with money left over compared to SS. You can repair a lot of aluminum props at $40 to $55 a job for the cost of major repairs. Just something to consider if you boat in an area with underwater obstructions.
Re: ss prop
Posted: Wed Jun 02, 2010 7:55 pm
by jim454
Thanks guys, thought I had heard something about a 50 being to small fot the SS prop, now it's been confirmed.
Re: ss prop
Posted: Wed Jun 02, 2010 9:06 pm
by lakerunner
Thats like going from a wood paddle to aluminum
