Currently it is powered by a 140 hp "iron duke" with an OMC 400 outdrive.
Any idea as to the weight difference between the OMC and an Alpha setup (I currently have several complete Alpha setups)
The only idea I've come up with so far is cutting out my existing motor well and putting a 14' or so john boat under the rear to mount the engine, batteries, and fuel tanks...
Also, if at all possible I would like to get enough speed out of it for watersports. Are there any better engine choices out there? The current engine is getting a bit tired anyway so I was looking in to replacement options. Do the 4.3 s weigh much more than the 4 cyl?
Lastly, Am I just better off going to outboard power and be done with it?
Please keep in mind, this is a budget project.. I currently have less than $2000 in it so far..
Thanks,
Doug
