Is my trailer not right?
mytee_hercules
#1 Post by mytee_hercules » Sun Jun 06, 2010 7:46 am
I noticed that the rails on my pontoons aren't resting on both rails like I think they should. Am I right in assuming that I should adjust them so the toons sit evenly on both rails on both sides?
Thanks in advance for the help. If my instincts are correct, looks like I may be spending some time fixing the trailer while my family gets to enjoy the water . . .
Hangin' in Little Rock . . .
1996 Sun Tracker Party Barge 24
1996 Force 120hp 4-cyl 2-stroke
15p aluminum prop
25 mph @ 4800 rpm
Woody
Re: Is my trailer not right?
#2 Post by Woody » Sun Jun 06, 2010 8:56 am
mytee_hercules wrote: Am I right in assuming that I should adjust them so the toons sit evenly on both rails on both sides?
Yes. :biggrin2
It shouldn't be too big of a deal to do though.
2019 Veranda 22 RFL 250SHO
#3 Post by lakerunner » Sun Jun 06, 2010 8:56 am
Just a matter of loosening bunk brackets and sliding them over a bit. using a come along pull them in till toons are settled in.
mytee_hercules
#4 Post by mytee_hercules » Sun Jun 06, 2010 10:35 am
You were right on -- a good socket wrench, rubber malett, and patience is all that's necessary to fix that problem (fortunately).
Thanks for the support . . . on to the next project . . .
15p aluminum prop
25 mph @ 4800 rpm
