I hope I didn't screw up too bad...
billyman
#1 Post by billyman » Fri Jun 11, 2010 10:25 am
Ever since I went from my old 70hp Force 2-stroke to the 70hp Suzuki 4-stroke, pulling the boat up on the trailer has been difficult (due to the add'l weight in the back). Usually my g/f pulls the boat up and I winch it tight. However, since mounting the new motor, it seems no matter how tight I winch it (within reason), the craft still settles an inch or so away from the stops. Anyway, the past few times out I have been experimenting w/ different ways to pull the boat up. Last night I tried increasing the throttle as she pulled the boat out that way there would be constant force against the stops which worked perfectly. However due to my excitement I forgot to turn the motor off. Instead I just slipped it into neutral. B/c the motor is so quiet I didn't realize it was still running for about 5 mins after we had pulled it out of the water.
So... my question to all the seasoned/experienced boaters is:
How much damage do you think I did to my new motor?
What should I do now?
All advice is appreciated.
1995 Fisher 200DLX w/ 2001 70hp Suzuki 4-stroke
Bamby
Re: I hope I didn't screw up too bad...
#2 Post by Bamby » Fri Jun 11, 2010 11:09 am
I did the same thing with my Honda a few times and no real harm came to it. Just make sure the motor is pissing OK the next time you launch it to confirm the water pump is still OK. And just keep an eye on things foe a while and hopefully you'll survive your experience OK too.
PS learn to pull key from ignition when boat is loaded to avoid future occurrences.
billyman
#3 Post by billyman » Fri Jun 11, 2010 12:49 pm
Bamby, thank you for sharing your experience and helpful words of wisdom. I hope no damage was done. I will be sure to watch that the motor is pissing as it did before.
#4 Post by lakerunner » Fri Jun 11, 2010 1:13 pm
Being you came from water not likely any problem but if you have a water pressure gauge keep an eye on it
#5 Post by curtiscapk » Fri Jun 11, 2010 1:28 pm
Should be ok I would think. I always turn key off, then to neutral. Or it may not start next time....been there done that. :lol3 :lol3
toondog
#6 Post by toondog » Fri Jun 11, 2010 1:51 pm
I believe the most damaged you might have done is shorten the life of your raw water impeller. It's one thing to crank the motor completely dry another if your impeller has some moister on it. If everything checks out OK on your next trip I would just make sure you change out the raw water impeller at the first schedule change. It is usually recommended to change it every two year, but some push it to 3 or 4 years with no problem. Now that you know it may have some abused, don't push it. :2cents
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
billyman
#7 Post by billyman » Sat Jun 12, 2010 12:59 am
Thank you all. Just came off the water after a midnight cruise & all seems to be fine. I'll keep your suggestions about the impeller in mind.
