20' G3 w/ 50 hp Yamaha 2 stroke prop and speeds?
cajunsmitty
#1 Post by cajunsmitty » Mon Jun 14, 2010 7:25 am
What pitch prob do you guys recommend for this setup? Also what rpm's and top end speeds should I be seeing? Thanks
timmac
Re: 20' G3 w/ 50 hp Yamaha 2 stroke prop and speeds?
#2 Post by timmac » Mon Jun 14, 2010 3:32 pm
cajunsmitty wrote:What pitch prob do you guys recommend for this setup? Also what rpm's and top end speeds should I be seeing? Thanks
1st off you need to go on Yamaha outboard website and there you can find the WOT rpm range, than you need to know your current WOT rpm now with current prop, than you also need to know what prop you have now. [your speed also would be great]
Once you find all this than you can see if you are having problems, maybe its running ok and you think its not ??.
Here is a link to a place that sells props, they show your rpm WOT range at 4500-5500, however I am not sure of your year.
http://www.piranha.com/ << old website, easy to read
http://www.piranhapropellers.com/ << new website
