20' G3 w/ 50 hp Yamaha 2 stroke prop and speeds?
Posted: Mon Jun 14, 2010 7:25 am
What pitch prob do you guys recommend for this setup? Also what rpm's and top end speeds should I be seeing? Thanks
Open and Honest Pontoon Boat Discussion
http://www.pontoonforums.com/
1st off you need to go on Yamaha outboard website and there you can find the WOT rpm range, than you need to know your current WOT rpm now with current prop, than you also need to know what prop you have now. [your speed also would be great]cajunsmitty wrote:What pitch prob do you guys recommend for this setup? Also what rpm's and top end speeds should I be seeing? Thanks
