150 hp yamaha vs. 225 hp yamaha?
I am ordering a 22ft. Bennington 2274GLI Triple toon performance package. & I am wondering about cost vs speed between 150hp & 225hp o/b. What kind of top speed should i expect from each motor? What do you guys think about the boat? What are the best options that i should get with it? Thanks ahead of time, my 1st time here.
Re: 150 hp yamaha vs. 225 hp yamaha?
buy the biggest motor you can afford. that will be the consenses here. im sure of it. no one ever complains they have to much power you always here i should of bought the bigger motor just my 2 cents.
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
115 Yamaha
karavan Trailer
2014 Chev tahoe
Port Of Bismarck ND
are you happy with your bennington?
- FloterBoter
it depends where you're going to use it and what you'll do with it.
22' is a shorter boat so both are plenty of motor, unless you'll
be on big water or need to pull a bunch of wakeboarders.
top speed only matters in a storm on a big lake.
I have a 2010 2275RLI with the ESP. It is powered by a 150 Yamaha. When I priced mine the 225 that I had in mind was almost 6K more than the 150. I get with 2 people 38/39 gps. If you plan on alot of folks and weight the 225 may be better for you. We had a larger group with us a few weeks ago and it takes longer if you want to go faster but with our group we were just talking and enjoying the ride at about 22 cruising. I have no experience with the 225 but the 150 is very quiet! At idle you can not hear it running. It is also very good on fuel. Hope that helps. Good luck! Bill
Bill & Lynn
2010 2275 RLI Bennington/ESP
150 Yamaha
Smith Mountain Lake, VA
150 Yamaha
tooned-out
I have a 2250 rcw Bennington with the ESP, I did upgrade from the 150 to the 200 ( a $4k upgrade ), it has plenty of power and I am pushing 48-49 for a top speed , keep in mind you are also going to need to get the power steering option which is another $2k, was it worth it ? I dont know but like most here I would rather have to much than not enough power.
2010 Bennington 2250 RCW
ESP Performance pkg.
Yamaha F200 4 stroke
I am at 40 with my 150. You probably will have to go to power steering with the 225. The sea star will get you by with the 150. What is max hp rating for the boat? Might look into the cost of the 175. Know the merc pro xs is suppose to put out more hp than stated on the cowl.
You looking at 2 or 4 stroke. Most 4 will be a little heavier. My guess on the 225 with the right prop is high 40's to low 50's
Thank you all. Ok so i am getting (at least i think) the 2011 2274gli, 225hp yamaha 4 stroke, with the ESP package,center tube storage, 54" gali,dual bimini,otteman,bow fill in seat, dual batt with switch, the stero and kicker amp upgrade, soft touch vinal, full vinal with snap in carpet, and abuncha more stuff that i may not even need. Im in the west coat but shopping all over US the best deal that i got so far it all this with the trailer for under $47k. What do you guys think?
I think you should be on it NOW in the lake!
Colorado Springs, CO.
Sounds like it will be a great boat. Need to remember to factor in delivery charge an the fact your dealer may be hundred of miles away. Probably no problem with the motor but not sure about the boat warranty locations or how that may work. Seems like there is always something not quite right with new boats.
Thanks Doc, the delivery cost is about $1k. and there is a bennington dealer near by for warranty work. I did go to them with the price that i have, just to try and get it from them and create a relatioship with them. But they wanted about $9k more for the same setup.
Another thing i am planning to add to the boat is a full camper closer. any ideas?
Thanks
Thanks
GREAT price for a great toon.
I would have Bennie make one that fits perfect
cncmaster wrote:are you happy with your bennington?
ooo yeah love this thing.
115 Yamaha
karavan Trailer
2014 Chev tahoe
Port Of Bismarck ND
115 Yamaha
karavan Trailer
2014 Chev tahoe
Port Of Bismarck ND
Good luck getting it built - perhaps in 4 to 6 months. Take any build date you get and add 3 months to it. Also don't expect any straight answers from Bennington as to delivery date. They won't return your calls.
Other than that I hear the boats are great.
no man ever said, "gosh, i wish it was smaller"
enjoy. for that coin, they need to make it perfect. one thing i've told my self is that if i ever bought new, i'd pop for the double bimini. with a 225 on that size you shouldn't lose much speed with that large of a sail up.
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
1989 Kawasaki 650sx
