Single Axle Trailer
yyj200
Single Axle Trailer
#1 Post by yyj200 » Wed Jun 23, 2010 7:10 pm
Does anyone know anything of Eagle Trailers, or have an opinion. It is for a 20', Bennington. I have a choice between an Ez Loader, or an Eagle. The Eagle has a higher GVW and surge brakes.The Ez Loader is just below the limit for requirement of brakes. One is a bolted frame the other is welded. Thank you.
Re: Single Axle Trailer
#2 Post by lakerunner » Wed Jun 23, 2010 9:42 pm
No nothing about Eagle but I just bought a new EzLoader and it is a very strong trailer. When you say bolted what do you mean?
yyj200
#3 Post by yyj200 » Wed Jun 23, 2010 10:05 pm
All joins on the trailer members are through bolted rather than welded to each piece. The yoke and hitch member are bolted on, and any additional cross members are also bolted.
#4 Post by ROLAND » Thu Jun 24, 2010 2:20 am
yyj200 wrote:Does anyone know anything of Eagle Trailers, or have an opinion. It is for a 20', Bennington..
I have a 20 foot bennington - it came with a road runner trailer. No brakes, all joints welded. I've don't have alot of experience with trailers, but I would think welds woud be strongest.
FloterBoter
#5 Post by FloterBoter » Thu Jun 24, 2010 1:04 pm
for a new trailer, welds would be the way to go.
on an old trailer (many years old), at least bolts can just be tightened up, or replaced with new hardware. to check the welds really requires grinding the paint off of them and taking a good look. i know of two old boat trailers that had welds break because moisture had gotten under the paint and corroded the weld over the years.
FloterBoter
#6 Post by FloterBoter » Thu Jun 24, 2010 1:05 pm
btw, if you come across a reasonably priced dual axle, go that route.
a blown tire doesn't mean you have to stop right there on that busy freeway.
they still only need brakes on one axle.
toondog
#7 Post by toondog » Thu Jun 24, 2010 4:26 pm
I also have a road runner trailer. It's has seen it's fair share of abuse and has never even hinted at a problem. It's welded too by the way.
Watch my boat pop up after the small tires hit a large rock.
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
