added a trolling motor
Posted: Fri Jul 23, 2010 6:47 pm
by ezmuny13
will post pics tomorrow...due to no front deck extension we had to fabricate a brace which turned out perfect.....installed a pontoon 55 from minnkota.....this bracket it came with is sweet,your able to remove when not in use
Re: added a trolling motor
Posted: Fri Jul 23, 2010 8:45 pm
by texaspontoon
When you get the motor going, tell me how it pulls your big toon around. Speed? Is it a 12 or 24 volt system? How long can in run on before it runs your batteries down? Is it a transom mounted or bow mounted on a bracket? (because I have been thinking about adding one but not sure how it would perform.
THanks...
Matt.
Posted: Sat Jul 24, 2010 2:19 am
by ezmuny13
k it's a 12v 55lb thrust w/52" shaft, bow mounted and will update other info...soon as possible
Posted: Sat Jul 24, 2010 4:55 am
by BassFrequency
Ive got the same setup on a 24' does pretty good. as for battery life, mine isnt a good comparison guide, yall have seen my battery
Posted: Sat Jul 24, 2010 4:49 pm
by ezmuny13
Posted: Sat Jul 24, 2010 9:13 pm
by texaspontoon
Thanks for posting the pictures. Tell me how it moves that big boat around will ya. I am thinking about either going with a trolling motor or a 15hp kicker. (I recently screwed up and put bad gas in my brand new Honda 150. Made it about 1/2 mile from the dock, and went dead in the water. It was embarrasing to be towed back by one of those "SeaDoo" boats, but I was glad for a ride. Even more painfull was the $400 bucks to flush the tank and motor. It is good to have "a little propulsion" in sittuations like that.
Posted: Sun Jul 25, 2010 1:43 am
by ezmuny13
yes,that's the main reason,but second never know when a person might want to rock fish in the fall/winter
Posted: Sun Jul 25, 2010 6:07 am
by HandymanHerb
Good job, but please tell me you don't have metal touching aluminum,dissimilar metal causes electrolysis and will eat on the aluminum.
So separate them and use SS bolts
Posted: Sun Jul 25, 2010 7:46 am
by ezmuny13
yes i do,and am using ss can i just put a ss washer between them
Posted: Sun Jul 25, 2010 10:45 am
by HandymanHerb
ezmuny13 wrote:yes i do,and am using ss can i just put a ss washer between them
Yea that should work, either or some rubber sheet, you just don't want them touching each other.
Posted: Wed Jul 28, 2010 9:00 am
by 95jagman
I added the MinnKota 55 lb 52 inch shaft to the front of my 22" Sylvan. I mounted the bracket UNDER the deck so you can't see it and it is out of the way. I also installed a remote on/off switch back at the fishing stations.
