Starting with Muffs
Posted: Mon Aug 02, 2010 10:50 am
by Brandon
Well, since the weather was horrible this weekend we were unable to take the boat out, and since it has not been started in two weeks I hooked up the muffs an hour or so after I changed the Gear oil. I started the motor and everything was find I let it idle for a few minutes while I cleaned up. I then started to notice after about 5 or 6 minutes of running that it started to smoke a bit, I was just wondering if this was normal at all or if there is any reason to worry.
The Gas that is in it has been in there for about 2 weeks just sitting, I dont know if that has anything to do with it, but I think its worth the mention
Re: Starting with Muffs
Posted: Mon Aug 02, 2010 10:56 am
by jmwhite
More information would be of help. Engine year, make, and hp. Where was the smoke coming from? Smoke color?
Posted: Mon Aug 02, 2010 12:22 pm
by WaltF
Mighta just been burning off some junk...
Posted: Mon Aug 02, 2010 12:40 pm
by Brandon
50 hp Merc 2000. The smoke was white, and I cant really tell you where it was coming from, I cut the motor off when I saw it
Posted: Mon Aug 02, 2010 5:38 pm
by Ghost Rider
Did you have a good sream coming out the pee hole. Most likley just exhaust smoke. I would not worry.
Posted: Mon Aug 02, 2010 5:49 pm
by slingshot
Are you sure that it wasn't steam? If you started your motor cold it would take a few minutes before it got up to operating temperature at which time the thermostat would open and allow steaming hot water out the exhaust hub.
Posted: Mon Aug 02, 2010 7:02 pm
by Brandon
There was steam, however there was smoke also. Its not like there was tons of smoke it was actually kinda hard to tell what was steam and what was smoke. When I seen the smoke I just turned the motor off I just wanted to make sure it wasnt something major.
Posted: Mon Aug 02, 2010 7:29 pm
by lakerunner
Would sure help if members would add to the signature line the make and type of motor and boat you have. We can't remember if you have a 2 or 4 stroke or I/O
Posted: Tue Aug 03, 2010 10:51 am
by Brandon
Your Right Lakerunner, I should have done that a long time ago
Posted: Tue Aug 03, 2010 11:50 am
by lakerunner
Now that helps. Normal for some smoke at idle or low speed. That's the nature of a 2 stroke
Posted: Tue Aug 03, 2010 2:06 pm
by Brandon
Thats good information to know, which is why I love to ask you guys questions on here. I probably would always be turning my motor off once it started smoking forever.
Posted: Tue Aug 03, 2010 2:39 pm
by JohnO
I think we need to get this "muff" person in touch with the person who's having a hard time starting his "johnson". Seems like a perfect match to me.
(The two threads are next to each other at this moment)
Posted: Tue Aug 03, 2010 4:57 pm
by slingshot
Nice!
Posted: Tue Aug 03, 2010 7:19 pm
by Snider4
Unless we are talking about huge amounts of smoke or the water was not flowing in the muffs it is normal. I have the 06 merc and it smokes too on muffs.
