Re: Quad-Toon transom design
Posted: Mon Mar 14, 2011 7:09 pm
by spurhunter
Why am I not surprised there is a keg on the boat during the build.... :nana :drink4 :bowdown :bowdown
Posted: Mon Mar 14, 2011 7:37 pm
by GregF
I think you are going to have a problem getting clean water to the motor unless you put a skid plate under the back of the center 2 pontoons. It doesn't look like you have room for a regular motor pod.
Posted: Mon Mar 14, 2011 8:43 pm
by margaritaman
I have seen pictures from a pontoon manufacturer that has the motor mounted in the rear of the right pontoon instead of the center. The manufacturer makes pontoons for commercial use and the right outboard pontoon will have the least water turbulence. I know it looks odd but I guess it works.
Posted: Mon Mar 14, 2011 11:22 pm
by GregF
Do you know a guy with a TIG machine? Welding that plate in is probably the best way.
Posted: Mon Mar 14, 2011 11:52 pm
by Ron Burgundy
Dual outboards...problem solved :lol3
Posted: Tue Mar 15, 2011 3:33 am
by ROLAND
spurhunter wrote:Why am I not surprised there is a keg on the boat during the build.... :nana :drink4 :bowdown :bowdown
come on now, you can't expect the man to work on his boat without the proper tools :drink
Posted: Tue Mar 15, 2011 6:35 am
by GXPWeasel
What if you made a motor pod type thing, that stuck back about a foot to 18" behind the two middle logs? What I mean is, you know how several of the newer toons have the motor pod or even 3rd log that stick back about 2 feet behind the outer logs, well do something like that. Link the two middle logs with some type of angle iron (or aluminum I guess) and build a makeshift motor pod that extends back from that. You could still brace this pretty well with the floor, plus it would be attached to the middle logs. I think this may get you a better chance at "clean" water as well, since it would sit back a bit from the actual logs of the boat, which is why I believe the newer 3 logger type toons do this.
Looks like a fun & interesting project for sure.
Posted: Tue Mar 15, 2011 8:46 am
by sam-toon
In your pictures that you have posted.....are there four logs on there when your on the water? They seem very very low in the water. With four logs that sucker should be floating high on the water, unless you have water in your toons somewhere. My opinion would be to weld an aluminum motor pod to your two center toons. I always thought if you do weld something it will have to be the same material(aluminum) and not the steel or other type you mentioned. I might be wrong but wont it cause some type of corrosion if you use two types? Nice build........the two motor option also sounds good, plus if you used two motors I would bet you would get better gas mileage vs using the one (it won't need to work as hard to push). Good luck, post some pictures when you decide what to do.
Posted: Tue Mar 15, 2011 9:09 am
by GregF
Trying to start trouble eh? ;)
I do agree if he matches the contour of the toons and isolates them to avoid rubbing this could work but you may get a lot of water trying to come up through that gap, soaking the bottom of the boat and wasting energy along the way.
I would stick with aluminum if you can to avoid galvanic action.
