ok..Noobie question about loading
Lunker
Re: ok..Noobie question about loading
#16 Post by Lunker » Fri Jul 15, 2011 12:55 pm
GregF wrote:Just be aware some ramp owners will kick you out and bar you for power loading. It is tough on the end of the ramp. Make sure it is OK before you do it on a strange ramp.
+1
2008 Lowe Suncruiser 22ft
2008 Merc 60hp Big Foot
Tandem Axel Karavan Bunk Trailer
kryptonite
#17 Post by kryptonite » Fri Jul 15, 2011 1:04 pm
Any time you power load, you shouldn't gun it. I always trim up and only give just enough throttle to move it up the trailer. If you have to gun it, then you are eroding the end of the ramps away.
Our ramp has a huge hole at the end. (DON'T ASK ME HOW I KNOW). Some ramps have concrete down a long ways, others only have it part of the way down.
SoapPeddler
#18 Post by SoapPeddler » Fri Jul 15, 2011 2:39 pm
This is good information for a newbie like me. :P
I got lucky. Right after I bought my trailer, a friend of a friend offered to let me park at their dock for the summer. Its only 1.2 miles from my house.
My trailer has bunks, but I didn't buy the guides. Would it be possible to make my own from 2x4"s and U-bolts or is it necessary to buy them from the marina?
Gi-Gi 2001 Sweetwater Challenger 18'
40 hp Merc
2005 GMC Envoy
2011 Mid States Trailer
Austin Lake in SW Michigan
chill'nthemost
#19 Post by chill'nthemost » Fri Jul 15, 2011 2:50 pm
I honestly wasn't aware you could load a 25ft toon any other way but to drive it on. I can't imagine trying to float on and stay lined up on the bunks
#20 Post by ROLAND » Sat Jul 16, 2011 12:42 am
SoapPeddler wrote:This is good information for a newbie like me. :P
I'm sure you could probably make a set of your own... I bought my 48" guides over the internet.... I think they're made by a company called "long Run"...
Drago
#21 Post by Drago » Sat Jul 16, 2011 5:54 am
Thought I would add my way. Right now I have quickly degrading carpet on wood bunks. I back the trailer in far enough to get the carpet wet, then pull out until the rear 12" of the bunks are submerged, then lock the truck down. Joy gets in the truck and I motor the boat into the 3 Vs of the bunks. This can be a bit taxing if there is a nasty crosswind. Once the front of the toons are wedged into the bunks, I use the motor to line up the rear and use a little power to edge forward. Joy can feel me making this move and will slowly reverse the truck and trailer to allow me to slide the boat up to the stops. At this point somewhat more than half the trailer is in the water. I walk up to the winch to hook up and can check to see if the boat is straight there. If the ramp is a steep one, make sure to trim or tilt up the motor a bit or you might put some extra cup on your prop when it encounters the concrete :cry: One more really important move - - kill the motor before telling Joy to slowly pull out. I usually get down as she pulls out to check the boats location on the bunks.
There have been times when the boat is not tight against the stops. When we get the truck/trailer straight and level we pull the RINKER MANEUVER -- stop the truck abruptly to slide it tight against the stops, then tighten the winch. This little move was taught to me by Jerry Rinker (65 year old fart that races trihulls and sells boats) and I'm fairly sure that it could have some negative side effects but I think "easy does it" is key to reducing damage.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
GregF
#22 Post by GregF » Sat Jul 16, 2011 7:52 am
My HOA will pull your key for power loading. They just spent $27,000 fixing the ramp.
As for the guides. I made mine with 2" gray PVC (UV protected electrical conduit). I used 2 90 degree sweeps and made a big "U" that bolts to the cross member in the back of the trailer.
I even had holes there to use. YMMV on that.
SoapPeddler
#23 Post by SoapPeddler » Sat Jul 16, 2011 5:22 pm
GregF wrote:My HOA will pull your key for power loading. They just spent $27,000 fixing the ramp.
YMMV?
40 hp Merc
2005 GMC Envoy
GregF
#24 Post by GregF » Sat Jul 16, 2011 5:28 pm
SoapPeddler wrote:
GregF wrote: As for the guides. I made mine with 2" gray PVC (UV protected electrical conduit). I used 2 90 degree sweeps and made a big "U" that bolts to the cross member in the back of the trailer.
YMMV?
Your Mileage May Vary?
You may not have the appropriate holes
