Electrical help
- evinrude2stroke
Electrical help
I need a little help here guys. I installed a Depth Sounder over the weekend and while I was searching for a Positive feed with my light tester I touched a connection behind one of my other gauges. I got spark and now I have no ignition power. I still have power to my radio & lights but not to my gauges or ignition. Anyone have an Idea?
I'm hoping it's just a fuse but as you can see I'm not that bright when it comes to this stuff.
Dave
Re: Electrical help
I had a main fuse close to the battery blow. Took me a couple times to find it. You might look there, but my toon is almost 20 years old..
Re: Electrical help
also check the fuse on the motor
most likely its a fuse somewhere
-bb
-bb
Re: Electrical help
It is a fuse in the motor if it was hooked to the ignition lead. Look in your owner's manual. There should be a fuse chart that tells the the size and location of each fuse. Mercury even puts a spare fuse in the snap around housing for the critical ones. YMMV
1974 Harris
70 HP 4 stroke EFI Yamaha
- evinrude2stroke
Re: Electrical help
Thanks guys. I'm going to check by the motor as soon as this rain lets up. I appreciate the replies.
Dave
Re: Electrical help
You blew a fuse, for sure. Check your bus bar first. The main fuse powers everything. If it was blown you wouldn't be getting power to anything else. Look for a wire coming from the ign. switch to the bus bar. That should be it. It also likely powers your lights in the gauges.
Look For The Burnt Fuse At The Bus.
1994 Party Cruiser 32'
115 Mercury O/B
Restored & upgraded
115 Mercury O/B
Restored & upgraded
Re: Electrical help
Yep, most likely a fuse. Here's a wiring diagram:
http://www.johnsonevinrudeoutboardmotor ... agram.html
- evinrude2stroke
Re: Electrical help
Wow. That Diagram is great. Thanks.
I'm hoping it's the fuse by the starter. My Marina is coming tomorrow to pick it up and put it in the water. I would rather find the problem and fix it myself than pay them to do it. Thanks again.
Dave
Re: Electrical help
Thanks Ed
This is the legend that goes with that picture
#5 looks like the culprit
1. Marine battery 10. 26-pin J1-B EMM connector
2. RED wire (POS) 11. 34-pin J1-A EMM connector
3. BLACK wire (NEG) 12. Engine Management Module (EMM)
4. Starter solenoid 13. YELLOW/RED wire, start
5. Fuse (10 amp) 14. BLACK wire, start signal ground
6. RED/PURPLE wire 15. Neutral Safety Switch (remote control)
7. 6-pin connectors 16. RED starter motor cable
8. Ignition switch 17. Electric starter motor
9. PURPLE wire (switched B+)
1974 Harris
- evinrude2stroke
Re: Electrical help
Yep. I'm going to check that as soon as I get home. Thanks.
Dave
- evinrude2stroke
Re: Electrical help
You guys were right. It was the number 5 fuse (10amp). Right by the starter. Thanks for all the help guys.
Ed, that diagram was on the money. Thanks. That made it alot easier to find.
Dave
Re: Electrical help
You're welcome, glad to help
