Any suggestions on prop size
onthelaketwo
#1 Post by onthelaketwo » Sat Sep 12, 2009 10:52 am
My current prop is alumnimum marked 14x11
The boat is a 25 foot manitou oasis with 2 toons
The motor is a 90hp evinruide etec
The boat now goes about 22 mph at 4900 RPM @WOT. with 500lb of passangers and full gas tank.
The motor should be able to go up to 5500 RPM.
What would be the suggested prop? I was going to get a new one, and use the current as a backup.
Thanks in advance.
2005 Manitou Oasis LF4
2006 Evinruide ETEC 90hp
Sea-legs installed
14x11
Re: Any suggestions on prop size
#2 Post by HandymanHerb » Sat Sep 12, 2009 11:01 am
Here's where a prop shop comes in handy, you get about 200 rpm for every pitch you go down, so your around and 8 pitch, but if you got a shop that will let you take a few to try.
Then you can buy the one you want and they can repitch your old one to match
big daddy
#3 Post by big daddy » Sat Sep 12, 2009 12:22 pm
same problem with the banana cabana, 24 foot running a 90h.p. etech I go close to 22mph at 4700 w.o.t. I really dont like turning up that high if its w.o.t. but as you stated we are supposed to be in the 5500 area. my prop is a 15x13 so dont buy that size is what i'm trying to say
hotairgypsy
#4 Post by hotairgypsy » Sat Sep 12, 2009 1:43 pm
i am in the process of installing a tach so i have a clue what my rpms are too so i can figure out the rigth prop size. is there a prop calculator around which could help us out with figuring out what is optimum. i have a 14x13 in my case and i assume i am changing the first number and not the second
rockymax
#5 Post by rockymax » Sat Sep 12, 2009 3:10 pm
Try powertechpropellers.com. They have a prop worksheet that you can submit for help. They have some very helpful people. Even though your prop may be the significant or only reason for the lower RPM's at WOT, sometimes the improper engine height is a major contributing factor.
23' Hurricane
250hp Yamaha
Madison, AL
Wheeler Lake (TN River)
mikeherb
#6 Post by mikeherb » Sat Sep 12, 2009 6:29 pm
Here is another good site for props:
http://www.dansdiscountprops.com
dockholiday
#7 Post by dockholiday » Sat Sep 12, 2009 8:33 pm
Seem to me you should be able to turn the 11p prop with 90 hp. Got any idea on the weight of your boat?
brumbyvet.1044
#8 Post by brumbyvet.1044 » Sun Sep 13, 2009 2:56 pm
I know you have a rude but you might try the mercurymarine.com site. They have a great prop selection tool. It would give you the diameter and pitch and then you could convert that to a evinrude prop. Good luck.
Garmin 430S
Cherokee Lake, TN
onthelaketwo
#9 Post by onthelaketwo » Sat Sep 19, 2009 6:15 pm
Boat weighs about 1850lbs plus 320lbs for motor. plus 27 gallons of gas, plus 500lb load during testing.
Sea-legs installed
14x11
dockholiday
#10 Post by dockholiday » Sat Sep 19, 2009 7:30 pm
onthelaketwo wrote:Boat weighs about 1850lbs plus 320lbs for motor. plus 27 gallons of gas, plus 500lb load during testing.
Actually think the wot should be around 5800. Does the above weight take into account the sea legs? Seems like your boat is near in weight to mine just figuring boat and motor. Is that rpm trimmed out as much as you can without blowout? Guess you could drop down a notch in pitch but seems like something else is going on. Have you checked it without the load of gas and cargo to see how it affects the rpm?
rockymax
#11 Post by rockymax » Sun Sep 20, 2009 5:26 am
I agree with Doc. You need to make certain that your trim is optimum. Also, is your engine at the correct height. After establishing this, if you have the ability to try a lower pitch prop, this will tell you if the prop pitch is the problem. When you determine the prop pitch you need, buy a Viper prop. This will give you the best rpm and top end speed for you Etec.
23' Hurricane
250hp Yamaha
Madison, AL
onthelaketwo
#12 Post by onthelaketwo » Tue Oct 06, 2009 7:21 pm
I did not get a chance to work on it yet. Lots of people have told me the 14x11 should be fine.
Maybe my RPM gauge is not reading properly. Any method to check easily?
I am going to reprogram the motor in spring to burn XD100 oil, I guess they can check computer to see top RPM recorded, as it records a histogram of RPM speed.
I guess it is a project for spring.
Sea-legs installed
14x11
Bamby
#13 Post by Bamby » Wed Oct 07, 2009 5:58 am
Seems a 14x11 should be fine on your boat a lot of folks I know with 90s actually run 14x13s on theirs. If your toons are filthy from a whole summers worth of crud that will both slow you down and effect top rpm performance. Recently I cleaned mine though not that cruddy I picked up almost 300 rpm's and some speed.
peapenl
#14 Post by peapenl » Wed Oct 07, 2009 8:15 am
I have the same motor on a 22ft crest and turn 5200rpms with a 14x11
