on board charger
- killerkernrich
on board charger
I have white stuff on my charger appears like the same stuff you might get on a battery post...it is a Minn Kota 2 bank for a 24v ... how would I clean it and what makes it get this way.?
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
Re: on board charger
I have never seen that but my first thought is salt. You boat in saltwater?
My second thought would be that you're getting some deposits from the degassing of your batteries as they charge. I know those batteries can expulse hydrogen gas among other things. If you are charging multiple batteries in tight quarters with no venting, it doesn't seem out of the realm of possibility that you would see some residue on your charger.
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
Can you post a pic or two of it?
I also have a MinnKota two bank charger.
Yamaha Vmax SHO 115HP
- killerkernrich
not in salt water.....can't get a picture right now its in dry storage up at lake 50 miles away from home, the Bats are sealed.
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
[quote="killerkernrich"]not in salt water.....can't get a picture right now its in dry storage up at lake 50 miles away from home, the Bats are sealed.[/quote]
I was wondering where the corrosion or oxidation is forming.
- killerkernrich
Joe , right on top of the charger.
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
Here is what I would do if I were you.
1) Check the fluid in your batteries. Make sure your charger isn't "boiling" your batteries.
2) Clean your charger off and go a week or two where you charge with your battery hatch open to allow ventilation to see if that white stuff comes back.
Also, do you see any of the residue on the other surfaces in your battery compartment?
- killerkernrich
I can't add water they are sealed gel
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
