Replacing my hubs
Replacing my hubs
I just ordered two super lube<-linky hubs. i am thinking of using my old bearing buddies instead of the caps that come with it. I figure with the zerk fitting out side in the rear, I could just fill from the back and let the bearing buddies keep the grease under pressure for extra protection. Anyone see a flaw in my thinking?
- super lube hubs.gif (36.19 KiB) Viewed 3673 times
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
Re: Replacing my hubs
Mine do that but my zerk fitting is behind the rubber seal, I remove it and it pumps the old grease out the front, i guess you could run the bearing buddies too wouldn't hurt.
But there so fast to add grease you don't need them.
That's how my work trailer and rinker trailer are. My pontoon trailer only had the buddy bearing caps and it was time to repack. (I hate working with greaseMine do that but my zerk fitting is behind the rubber seal
The way I understand how the bearing buddies work, they keep the grease under pressure even after you put your trailer in the water. Keeping the water out. With just a rubber plug, water sometimes gets sucked in. The down side to bearing buddies is having the rear seal blow out.
I just thought I would get a second opinion in case I was overlooking something. I don't know of anyone that use both.
toondogs quick tip
I just recently learned that you are supposed to rotate your tire (hub) while you pump the grease in.
Got my new hubs on, pretty simple swap. The one down side to this style is that you may need to remove the tire to get good access to the jerk fitting. Still better than bearing buddies by them selves though. I had read the the caps that came with these were crap and they were not lying. Tried to put them on my old hubs (which I will use as spares) and they pretty much got bent out of shape
The bearing buddies went on perfectly, thank god.
For tight places you need one of these couplers for your grease gun. 90° grease coupler I am not affiliated with this store, it is just the first example I could find.toondog wrote: The one down side to this style is that you may need to remove the tire to get good access to the jerk fitting.
Hope this helps.
gerg
2003 SunTracker Party Barge 200 'RiffRaft'
2017 Mercury 60hp Command Thrust
Brookville Lake, Indiana
- Why do they call it Common Sense when so few people seem to have it? -
Hey thanks, that looks like it would come in handy.
