2004 60hp Merc 4 stroke
silverfarm
#1 Post by silverfarm » Wed May 05, 2010 7:48 am
Hey guys...thinking about changing the oil and plugs myself...is this something a novice (at best) could do?
1997 Fisher 200DLX
2004 Merc 60hp 4stroke
slingshot
Re: 2004 60hp Merc 4 stroke
#2 Post by slingshot » Wed May 05, 2010 8:06 am
Very easy, here's a couple of video which explain it all:
http://www.youtube.com/watch?v=gGU8I3y-_Gc
http://www.youtube.com/watch?v=wcTRUNIK1w0
To drain the oil you probably have a drain bold on the mid section of the OB you can just remove and not use the pump.
2007, 2570 Crest LE II
Yamaha F150
#3 Post by curtiscapk » Wed May 05, 2010 8:19 am
First Welcome!
you need to put your toon in your profile or signature so we know what you have.
I assume its a 4 stroke and yes you should be able to do both.
GXPWeasel
#4 Post by GXPWeasel » Wed May 05, 2010 8:50 am
Welcome !!!
Sure you can do this yourself. When changing plugs, just make sure you have the correct wire back on the correct plug. Just do 1 at a time, and you should be good to go.
"Nauti Weasel"
2005 Beachcomber Islander 26
