Using Eyebolts to Pull . . . What do you think ?
Re: Using Eyebolts to Pull . . . What do you think ?
Rhino that is one ugly toon!!!
- IMAG0043a.jpg (114.71 KiB) Viewed 4519 times
OK I missed the Steel bolts through Aluminum before, that's a big NO NO, dissimilar metals is going to make a battery and start eating the aluminummytee_hercules wrote:So it looks like two big beefy u-bolts through the aluminum hull and supported with steel plates on top and bottom would work well for pulling and towing . . .
U-bolts are better than an eyebolt due to the fact that two bolts through the hull will support better than one . . .
Thanks for the inputs -- would love to get more if they are out there . . .
Yep, never use dissimilar metals.
- mytee_hercules
Jealous 'cause it's not that RED color ?curtiscapk wrote:Rhino that is one ugly toon!!!![]()
Alright -- no dissimilar metals -- got it. So what kind of bolts do you use to keep all your things secured on your craft?
(Hmmmm . . . . this may require more picture-taking on my part to clarify my concerns . . . )
Hangin' in Little Rock . . .
1996 Sun Tracker Party Barge 24
1996 Force 120hp 4-cyl 2-stroke
15p aluminum prop
25 mph @ 4800 rpm
15p aluminum prop
25 mph @ 4800 rpm
dockholiday
should know this, but think as long as they are not touching is the idea on dissimilar. Might be able to shim it on either side.
mahogany or teak come to mind, or maybe some nylon washers.
Stainless steel only.
- mytee_hercules
Ah Ha !badmoonrising wrote:Stainless steel only.
So, as long as the bolts and washers are stainless steel, there is no problem using them for towing points or docking points or whatever.
Another good thing to know . . . that could have become a bad thing.
15p aluminum prop
25 mph @ 4800 rpm
15p aluminum prop
25 mph @ 4800 rpm
- mytee_hercules
Let's ask the question one more time with pictures . . .
- Tow question.jpg (104 KiB) Viewed 4385 times
15p aluminum prop
25 mph @ 4800 rpm
15p aluminum prop
25 mph @ 4800 rpm
Personally, I'd go with the u-bolts. They will have double the shear strength of eyebolts. If going through plywood, use large washers...
Rhino,
what is that on your port toon hooked to the eye?
- mytee_hercules
It's just a line that the previous owner had tied there. It's not attached to anything and I did remove it since I didn't see a need for it there either.curtiscapk wrote:Rhino,
15p aluminum prop
25 mph @ 4800 rpm
15p aluminum prop
25 mph @ 4800 rpm
I use the welded on eyes to tie up to my dock all season long. I didn't know that I shouldn't do that. Is it for stress reasons? Cracking at the welds? Does anyone have a link or some more sources? Why would they put them on if we're not supposed to use them? I always figured they were stronger than the cleats. I will inspect them closely when I get home to see if there are any signs of cracking.
Learn something new every day I guess..........
Matt & Kerrie
----2004 Aqua Patio 240RE----Cross Lake-Western NY
Onion Creek Farms----Rubs, sauces and spices----"Eat well, laugh, and enjoy life"
They are pretty weak when pulled from the sides. A couple of guys with pontoons used them to tie up on our floating dock in our marina and they got bent all to hell. That's what got me to call Tracker. They said to use the factory cleats only. Then again it's pretty rough on the upper Chesapeake, on a lake it may not be an issue.
