the wonders of muriatic acid 4 cleaning crap off the engine
hotairgypsy
it is amazing how well muriatic acid diluted works on getting crap off the engine and boat. It is a 50/50 mix of acid and water. for those who do not know you can get two gallons of muriatic acid at home depot for about 11 bucks. i put it through a portable sprayer in a very well ventilated(outside) area. very little wind. All i did was apply it, waited 10-15 minutes, then washed it off with water..i didn't wash it off with a rag. I didnt have the proper stuff to handle it up close so just washed it off. this is how well it works all on its own...just imagine if i had used a rag to wash it off(soap and water in a bucket).
- before1.jpg (610.03 KiB) Viewed 2986 times
- after1.jpg (549.75 KiB) Viewed 2984 times
- before2.jpg (565.98 KiB) Viewed 2981 times
- after2.jpg (579.48 KiB) Viewed 2979 times
Re: the wonders of muriatic acid 4 cleaning crap off the engine
Wow, very nice. Good thing whoever was auctioning that off didn't do that or it would have cost $1500 more!
dockholiday
Yep it does work well, used it all the way back to the late 60's for various things mainly to clean concrete. Use to have to get it at a builders supply that was pre HD Lowes etc. What kind of sprayer are you using. Every time I ran that or a bleach solution through a sprayer pretty much quit working. Everything from the hand kind to garden type pump up. Still worth it if you get a cheap one,
shit! that looks good hag
Fire that sob up!
Looks really good. Try it one more time, with a rag or brush this time, then slather some wax on it, and you'll be good as new ( looks wise anyways ).
"Nauti Weasel"
2005 Beachcomber Islander 26
- FloterBoter
i love the smell of acid in the morning.
smells like global warming. mmmmm.
