Boat Cover Support Poles???
Wondering what I can use to keep the water draining off my cover properly??? Thought I saw a thread on here a few days ago about what others use, other that the store bought stuff. Can't seem to find it now. Should I make my own, or is it worth buying some. My boat is an 18' Fisher, so how many would I need?? Thanks!
dockholiday
Re: Boat Cover Support Poles???
Think it is either or. You could make some but I like having them adjustable although you could use the pipe into a pipe an drill holes to make them adjustable. My current cover has the vents at the ridge poles an they really help keeping it cool under there. That is what I would do. Think overton or west marine carries them.
I use the same as dock, the vent type, installed them myself, they're very easy to install. Got mine off ebay for about 1/3 the price as overtons and elsewhere. Let me try to find the link and I'll let you now. You can also get the poles at a good price.
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
this is what I had
use now
use now
I like it Lakerunner, this is exactly what I did, but I don't have a fitted cover. I'll get some pics and post soon. If the toon is sitting on level ground I've never had standing water. Fairly cheap too. I used 1.5 pvc.
"If 10% is good enough for God, then 9% should be just fine for the Federal Government"
Herman Cain - Aug 18 2011
1997 90hp 2 Stroke Merc
1997 Sun Tracker Fishin' Barge 21
Thanks Lakerunner, looks effective and sturdy. Is that quickcrete in the coffee cans???? Jeffybear, please post your pics if you can, as mine is not a fitted cover either. Thanks to all for the suggestions!
Yes it is quickcrete. I drilled a hole in PVC in bottom of coffee can and ran a piece of re bar through to keep from slipping out of concrete. I used 3/4" pvc in can I then put a 1" inside 3/4. While under cover Betty raised it up till tight and marked it then I drilled a hole for a bolt. On top I used a 1/2 cap with a 2"cap screwed to it using a recessed screw hole.
The only place we had water pool was over tanning pad. That's why I made the modified A frame. Hint-- ink from pvc pipe will permanently stain vinyl so cover it or be sure and remove writing on pipe.
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
took me a while but I've got pics as promised.jeffybear wrote:I like it Lakerunner, this is exactly what I did, but I don't have a fitted cover. I'll get some pics and post soon. If the toon is sitting on level ground I've never had standing water. Fairly cheap too. I used 1.5 pvc.
- View of the cover. It's always nice and tight. Never had to push water off of it.
- cover.jpg (93.41 KiB) Viewed 8488 times
- view of bucket
- bucket.jpg (52.3 KiB) Viewed 8481 times
- view of the extender
- extender.jpg (48.3 KiB) Viewed 8481 times
- Here is view of the support foot. I purchased buckets from lowes, then filled them with quickcrete. I inserted a 2" pvc section into the quickcrete and then once it hardened I can insert the longer pvc tube, I then drilled through that and placed and extender and drop a 1.5" pvc down through that. This way I figured I could make the support whatever height I needed. One thing I wish I had done that Lakerunner did and that is to place a stick or rebar or something complete through the bucket, occasionally my quickcrete section will slide out of my bucket when I am removing it from the toon.
- pvcSupport2.jpg (89.31 KiB) Viewed 8506 times
- View from aft to bow. I did not glue any of the joints, glad I didn't, I think I'm gonna extend the 3 sections to 4 and get rid of the two that are on either side of the seat near the bow.
- pvcSupport3.jpg (117.02 KiB) Viewed 8504 times
- This shows pvc supports. I have one smaller one in the front (not visible), followed by two on both sides of the deck lounge/livewell, then 3 connected to each other to the aft of the toon.
- pvcSupport.jpg (100.2 KiB) Viewed 8494 times
I like
