Rod Holders for square rails?
So what are you guys using for fishing rod holders on the square rails?
I may have to reinforce one or 2 either way for flatheads, but for normal fishing?
thanks
-bb
thanks
-bb
Re: Rod Holders for square rails?
I saw some on eBay... they had rod holders, drink holders and I think lantern holders!
1999 Riveria Cruiser 24'
2000 Mercury 50 hp 2 stroke
I use a scotty rod holder with a squared off U bolt.
What about something like this below.
http://nativewatercraft.com/accessory.cfm?id=123
- rod_holder.jpg (11.83 KiB) Viewed 6767 times
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
- lakerunner696
This base http://www.cabelas.com/product/Driftmas ... l+Products
The holder
http://www.cabelas.com/product/Fishing/ ... t104538780
The holder
Last edited by lakerunner696 on Mon Apr 25, 2011 9:27 pm, edited 2 times in total.
2008 F150 Lariat Super Crew
Haul Rite trailer
Haul Rite trailer
captainjack
Drift master are the only ones I have found that are solid. Scott's are ok on the right application if it is on open rail with no seats or tin interfering with mounting. If the scotty's catch while pulling into a dock they can really damage the tin. I have heard but off the back a of a toon other than looks I prefer scotty's functionality.
2008 Playcraft Extreme 2600
2008 300 Mercury Verado
2008 Bear Trailer
Iowa
2008 Bear Trailer
Iowa
spurhunter
I just installed the Scotty/Cabels brand since I already had the holders off my old boat. I really like the application of these. I am not a huge fun of the SCotty's, but since I had them......
http://www.cabelas.com/catalog/product. ... basket.jsp
1985 Johnson 175 gas guzzler
2007 2500HD Duramax Z71
I've been using the Scotty's (labeled west marine brand) and haven't had any problems. I also use the mounts that fit over the square rails, which means no drilling through the rails and since my boat was new last year the thought of drilling the rails wasn't appealing. I'm getting over it a little bit this year. Also, since the mounts use screws underneath if you want down the road moving them to another location is pretty easy and quick.
Fortunately I have enough open rail on my boat that we can mount them pretty much where ever we want them using the square rail mounts.
200hp Mercury Verado
I m a little adverse right now to drilling, since 1) I may change my interior config, and 2) what if I dont like em int that spot.
I just saw these on the side of a link from above
http://www.cabelas.com/catalog/product. ... BIK-013479
-bb
-bb
oh and has anyone had trouble with large fish and rail mounted rod holders?
would want a flathead tearing up my rail while I am asleep
-bb
-bb
- scfishnman
Driftmasters work great. No worry with big flatheads if you are using them. Also, the mounts that attach to your rails are very unobtrusive when the rod holder is removed. The rod holder just screws into the mount so it only takes a few seconds to put the rod holder on or to remove it.
-- Aqua Patio 240DC triple toon 225 Yamaha 4-stroke
-- 17' Polar Kraft w/ 75 hp Evinrude Etec
-- Yamaha Waverunner FX Cruiser HO
-- Yamaha Waverunner FX HO
- lakerunner696
scfishnman wrote:Driftmasters work great. No worry with big flatheads if you are using them. Also, the mounts that attach to your rails are very unobtrusive when the rod holder is removed. The rod holder just screws into the mount so it only takes a few seconds to put the rod holder on or to remove it.
Plus with the reel between the front and rear supports you won't loose your rod to a big fish or hangup.
Haul Rite trailer
Haul Rite trailer
cool,
just saw they have clamp on adapters too,
http://www.fishingpharmacy.com/driftmas ... p-274.html
what angle/model are you guys using? since the angle is not adustable I have to pick carefully I guess
I ll probably get 2 and I have 2 plastic BPS models that I am going to modify to work for the lighter stuff.
2 weeks ago this guy caught a 47lber from a spot we left.
thanks
-bb
thanks
-bb
- lakerunner696
I use the ones shown. I like my rod straight out not angled up.
Haul Rite trailer
Haul Rite trailer
Nighthunter
Everybody on Lake Conroe says Bee Ready Rod Holders are the best. Most drift for Catfish weighing 50+ lbs. and have had no issues. Bee Ready also makes brackets to clamp on square rails. http://www.beereadys.com/
