deck material?
BiXLL
deck material?
#1 Post by BiXLL » Sun Aug 07, 2011 11:12 am
In my shopping for a boat I have noticed Suntracker and another brand (I forget which) offers an aluminum deck on some models. To me, I would think this would be the ultimate material to use not only thinking of the wood rot aspect, but also weight. Why is this not more common on pontoon boats?
2013 South Bay 522CR tritoon
2013 Yamaha 115
lakerunner696
Re: deck material?
#2 Post by lakerunner696 » Sun Aug 07, 2011 11:33 am
I would think cost
2008 F150 Lariat Super Crew
Haul Rite trailer
Re: deck material?
#3 Post by Bamaman » Sun Aug 07, 2011 3:15 pm
Originally, just about every pontoon boat came with marine plywood decking. Then, many companies started using aluminum before switching back to plywood.
My Starcraft pontoon is 26 years old, and all of my decking is good--except for the small pieces on each side of my motor. The back end of my boat does get some blowing rain through the end of my boathouse.
If boats are kept out of the rain, marine plywood has a long, long life span. Also, plywood is much quieter and has less vibrations. The most important reason they're back using plywood is that it's much more structurally sound than aluminum sheeting--with much less flexing.
chill'nthemost
Re: deck material?
#4 Post by chill'nthemost » Sun Aug 07, 2011 3:46 pm
Bamaman wrote:Originally, just about every pontoon boat came with marine plywood decking. Then, many companies started using aluminum before switching back to plywood.
That depends on the amount of bracing, there isn't anywhere on our aluminum deck that has any flex...at all.
lakerunner696
Re: deck material?
#5 Post by lakerunner696 » Sun Aug 07, 2011 6:39 pm
Same here. they don't use sheets but extruded locking pieces. It also doesn't rattle
Haul Rite trailer
waterlab
Re: deck material?
#6 Post by waterlab » Mon Aug 08, 2011 7:09 am
There isn't any flex in our Party barge either.
The_Hellbilly
Re: deck material?
#7 Post by The_Hellbilly » Mon Aug 08, 2011 7:35 am
lakerunner696 wrote:I would think cost
I harass my pontoon manf. buddies about this on a regular basis. They have the typical "saleman" spill about how an aluminum deck will rattle, screws will loosen, etc. but have admitted that it all comes down to cost. They don't feel that their "typical" wants to pay the additional cost for an aluminum deck. That, and it is easier to manf. a wood deck.
2005 Voyager 22ft Tritoon
2004 Honda 135hp
RonKMiller
Re: deck material?
#8 Post by RonKMiller » Mon Aug 08, 2011 7:46 am
If I was buying a new boat it would definitely have aluminum decking - even for the extra cost since there is a significant weight savings.
When I rebuilt my deck I ended up with 5/8" Meranti 7 ply Marine plywood which does not flex on 16" centers - solid as a rock.
I also strongly considered using a plastic honeycomb composite which once again is a fraction of the weight of plywood:
nida core honeycomb.jpg (57.97 KiB) Viewed 4707 times
playcat
Re: deck material?
#9 Post by playcat » Mon Aug 08, 2011 7:52 am
Nice stuff, but out my my league cost-wise. I would love to reduce the weight of my barge but it ain't happening.
playcat
JC 266 TriToon
Kerr Reservoir, VA
Re: deck material?
#10 Post by badmoonrising » Mon Aug 08, 2011 9:34 am
You can't beat Track Duradeck..the main reason why I didn't agree to total my boat was that the 2010 and 2011 Party cruisers have plywood decks. Zero flex due to it's design.
