#16
Post
by dockholiday » Fri Sep 02, 2011 7:21 pm
wrd1972 wrote:Woohoo. Finnaly got the boat and it does 33mph top closed and 29 top open with 2 adults, 2 kids. It feels like any other pontoon up to about 23mph then it starts to plane and accelarates even quicker to top speed. Needless to say I am very pleased.
pretty quick was that speedo or gps speed? Those suntrackers never stop amazing me.
wrd1972
#17
Post
by wrd1972 » Fri Sep 02, 2011 7:53 pm
dockholiday wrote:wrd1972 wrote:Woohoo. Finnaly got the boat and it does 33mph top closed and 29 top open with 2 adults, 2 kids. It feels like any other pontoon up to about 23mph then it starts to plane and accelarates even quicker to top speed. Needless to say I am very pleased.
It was on GPS. Boat does not even have an on-board speedo.
This was the first time I have had it out and I do think it still has a little more in on the OE prop if I play with the trim..
jeffybear
#18
Post
by jeffybear » Sat Sep 03, 2011 6:51 am
With GPS I noted that I had mine up to 24MPH with 4 onboard and pulling one on a tube. I was pretty satisfied with that. Of course mine doesn't have the strakes.
wrd1972 - What are your specs?
"If 10% is good enough for God, then 9% should be just fine for the Federal Government"
Herman Cain - Aug 18 2011
1997 90hp 2 Stroke Merc
1997 Sun Tracker Fishin' Barge 21
wrd1972
#19
Post
by wrd1972 » Sat Sep 03, 2011 9:18 am
sunedog
#20
Post
by sunedog » Sat Sep 03, 2011 10:34 am
Congrats and great looking boat. But your bimini boot is on upside down.
jeffybear
#21
Post
by jeffybear » Sat Sep 03, 2011 5:54 pm
did u get this at BP? was it a trade-in? Do you happen to know what size of prop it has?
wrd1972
#22
Post
by wrd1972 » Sat Sep 03, 2011 6:16 pm
It was purchased at a Marinemax dealer.
Well I got to drive it quite a bit more tonight. I manged 32mph (GPS) with the bimini up and 36 bimini down with two adults and two kids. The OE aluminum prop is 13.75" x 15 pitch. It also seems to be very easy on the gas which is a big plus. You can clearly tell when the boat gets up on plane around 23MPH and it really cruises nicely at 25MPH. You can also clearly tell when it falls off of plane when you hit big wakes.
spurhunter
Post
by spurhunter » Sun Sep 04, 2011 6:49 am
That is great!
1985 Johnson 175 gas guzzler
2007 2500HD Duramax Z71
jeffybear
#24
Post
by jeffybear » Sun Sep 04, 2011 8:25 pm
wrd1972 wrote:It was purchased at a Marinemax dealer.
Noted that you have a 4 stroke, mine is a 2 stroke, will that same size prop work just as well on my 2 as it does on your 4?
wrd1972
#25
Post
by wrd1972 » Mon Sep 05, 2011 5:02 am
jeffybear wrote:wrd1972 wrote:It was purchased at a Marinemax dealer.
Sorry. I am too much of a rookie to answer your question. I am sure someone else will chime in.
kenbob26
#26
Post
by kenbob26 » Mon Sep 05, 2011 8:13 am
i am trying to get better top speed out of mine too,i have an 08 suntracker fishin barge 21 ft 90 merc 2 stroke,top speed with 4 people (2 adults, 1- 80 lb kid and 1-80 lb dog)is 27mph on gps,5600 rpm,my prop has numbers stamped on it 17344a45p17,not sure what it all means but 17 pitch ?any suggestions,it pulls waterskiers ok,but struggles to get on plane with 4 adults and kids,thanks in advance kenny
08 suntracker fishin barge 90 merc 2 stroke, strakes,05 silverado 2500...what a long strange trip its been
brumbyvet.1044
#27
Post
by brumbyvet.1044 » Mon Sep 05, 2011 10:32 am
Wow, looks like you've got exactly the same boat as mine. Your prop should do fine if you are going to have a boat load of folks or plan on doing tubing or skiing but with proper prop and correct use of trim boat can go much faster. It is a great boat but it will take a little time behind the wheel to get the most out of it. I've had mine to 39 mph, GPS.
Garmin 430S
Cherokee Lake, TN
wrd1972
#28
Post
by wrd1972 » Sat Oct 08, 2011 8:28 pm
Got some speed results with a full boat today.
With 6 adults and 2 kids (1250 pounds), the boat could not get up on plane and the best speed was 16MPH plowing through the water like a typical pontoon boat. Ended up having to cruise at 3200 RPM which gave around 12MPH. Tried trimming it, shifting loads and no way was it gonna get up.
With 4 adults and 2 kids (915 pounds), it easily made it up on plane and still made 30MPH but it took a little longer to reach that speed.
Looks like the magic number is around a thousand pounds then it does not want to get up on plane. Regardless I am cool with its performance overall and I just thought I would pass the informationmation along. I still have not seen a faster pontoon on the lake and I have had several folks ask me, how its as fast as it is.
#29
Post
by ROLAND » Sat Oct 08, 2011 10:53 pm
wrd1972.... congratulations on the new toon.. She looks GREAT. Hope you and your family get many years of enjoyment out of her... thanks for the pics... great looking toon.
