E-Z Fender
Re: E-Z Fender
Re: E-Z Fender
I like it! send a Hi-Res to me, if you can....
Thanks!
Thanks!
- landlockedsailor
Re: E-Z Fender
Even without the logo, the EZ Fender is gorgeous! Oh, and the sunset is nice too!
Landlocked Sailor
Re: E-Z Fender
Done and done. I emailed it to ezfender as it was too large to pm to you.Bryden24shp wrote:I like it! send a Hi-Res to me, if you can....
Thanks!
They've survived a full summer on board, which is pretty good considering the abuse that boat takes
Re: E-Z Fender
Bryan - I promise I'll get pics for you this weekend. I put the EZ Fenders on last year and they have been great. I have to remove one of my bumpers to help support part of my cover and it's very easy to remove the bumper and then to set it up again when the cover is off.
My neighbor saw them and he is going to get a set as well.
Re: E-Z Fender
Thanks Steve! Send em on! Working a turnaround at our plant for the summer, no time to do much more than package and sell my inventory, but as soon as the 13 on and 1 off 12 hour shifts are over, I'll get the webpage updated.... I promise! I won't be able to enjoy my summer until November, when I winterize the boat!
You guys are great!
Thanks Alot!
You guys are great!
Thanks Alot!
Re: E-Z Fender
I was wondering about after you install these will they rub a hole in my cover? Can they be installed on the bottom side of the rail or will the screws get pulled out because of the tension? Thanks, they do look good.
David
David
2005 JC 246 24" Tri-toon 5.0l V-8 "Can't You Sea"
2015 F-150 3.5 Eco Boost, Platinum
2004 F-350 Superduty, bulletproofed
2019 Toyota Highlander
30' Coleman 300 TQ
Several 4-Wheelers
Casper WY
30' Coleman 300 TQ
Several 4-Wheelers
Casper WY
Re: E-Z Fender
My rail was below the top edge of the seat so it doesn't even touch the cover. You can mount them below without issue also, we mounted one of them sideways on a boat because of clearance issue and haven't had any trouble.
[b][i]
[/i][/b]
[/i][/b]
Re: E-Z Fender
firedog wrote:I was wondering about after you install these will they rub a hole in my cover? Can they be installed on the bottom side of the rail or will the screws get pulled out because of the tension? Thanks, they do look good.
David
My buddy mounted his to the bottom of the top tube on his rails. Works like a charm
Re: E-Z Fender
I have had people worry about that, but never have had anyone tell me it did wear through. Depends on the placement. Mounted behind the furniture backs, there is usually a good void to get them into. I do profile the edges, too. So they are rounded before I tumble them. If it looks like its going to be a problem, I just suggest some iron on jean patches on the bottom of the cover. I did it to my old Manitou just to try it, and it worked. But I have sold over 4000 pairs now, and haven't heard of a wear through in the 7 years I've been selling them.firedog wrote:I was wondering about after you install these will they rub a hole in my cover? Can they be installed on the bottom side of the rail or will the screws get pulled out because of the tension? Thanks, they do look good.
David
As far as tension pulling the screws out, the only tension should be the weight of the bumper, they aren't for docking lines, just holding your fenders in place. But they do take a lot of abuse from the bumpers getting pinched between the boat and the docks in rough water. But again, I haven't heard of any mounting screws being pulled out.
Any more questions, just holler! I've sold 1000's to these guys here. They are my EzFender test crew!
Thanks Guys!
Re: E-Z Fender
I wave a flag in honor of EZFenders!
- SAM_3774.JPG (157.23 KiB) Viewed 12986 times
Re: E-Z Fender
Craig is always coming up with stuff to make me smile.
Thanks Buddy!
Thanks Buddy!
Re: E-Z Fender
I'm sure it's been covered somewhere before but what's the recommended number of fenders per side on a 25ft pontoon? I'm picking up a boat later this month and would like to have these ready to go.
Thanks!
Thanks!
'Miss Kelley'
Yamaha F200 LB
14.5" X 15P SS Reliance
2015 Ram 1500 Eco Diesel
Yamaha F200 LB
Re: E-Z Fender
Personal preference really. I have 2 per side on a 24 ftr.
Don't forget to tie a knot at the end of your bumper line....or you will lose a fender....
- SAM_3055.JPG (241.68 KiB) Viewed 12907 times
- SAM_0973.JPG (285.91 KiB) Viewed 12937 times
- SAM_0976.JPG (288.16 KiB) Viewed 12936 times
Re: E-Z Fender
Good tip about the knot. Wish I would have thought about that last summer. We had one of the thumb screws back out and we lost a fender. Luckily the thumb screw ended up on the floor of the boat and not at the bottom of the lake.curtiscapk wrote:Personal preference really. I have 2 per side on a 24 ftr.
Don't forget to tie a knot at the end of your bumper line....or you will lose a fender....![]()
