Here's a teaser for you!
fredeboy
Re: Here's a teaser for you!
#16 Post by fredeboy » Thu May 01, 2014 8:34 pm
Bob That is awesome!! :nana :nana :nana
BobG
#17 Post by BobG » Mon May 05, 2014 6:25 am
OK, so it's installed!
Here it is retracted, tucked up under the belly:
And here it is extended. Note that the motor ends up below the bottom of the toons:
cwag911
#18 Post by cwag911 » Mon May 05, 2014 7:08 am
Nice job Bob ! :alright
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
smoker62
#19 Post by smoker62 » Mon May 05, 2014 7:35 am
What kind of controls are you using ? How do you know when it is turned correctly for retraction ? Is the accuator strong enough to hold it up with repeated bouncing on the rough water ? No I am not copying your design , I am not that ambitious . :lol3
#20 Post by curtiscapk » Mon May 05, 2014 8:43 am
that looks awesome! So its fixed in that position and you use forward or reverse for left and right??? Next freaking millioniare! :bowdown
Waterlogged
#21 Post by Waterlogged » Mon May 05, 2014 10:53 am
Does it clear the guide ons when you launch or retrieve? It just looks very close. Either way, nice work.
Glenn
2008 Mercury 115 4 stroke
smoker62
#22 Post by smoker62 » Mon May 05, 2014 11:15 am
curtiscapk wrote:that looks awesome! So its fixed in that position and you use forward or reverse for left and right??? Next freaking millioniare! :bowdown
My trolling motors never had a reverse, but Bob was an electrical engineer right ? :donno
bassn386
#23 Post by bassn386 » Mon May 05, 2014 11:27 am
You might as well get a machine shop up and running. This could be your third career!
F225 Yamaha
BobG
#24 Post by BobG » Mon May 05, 2014 2:19 pm
Actually, I'll be moving all the guide-ons to the other gap.
The actuator is rated for 200 pounds, so I think it'll handle everything I throw at it.
BobG
#25 Post by BobG » Mon May 05, 2014 2:22 pm
Interestingly, the MK55EM controller just has a knob you rotate left for reverse, through right for forward, (or maybe the other way around) so it ends up working just like a steering wheel, when mounted on the dash.
BobG
#26 Post by BobG » Mon May 05, 2014 2:26 pm
smoker62 wrote:What kind of controls are you using ? How do you know when it is turned correctly for retraction ? Is the accuator strong enough to hold it up with repeated bouncing on the rough water ? No I am not copying your design , I am not that ambitious . :lol3
Actually, I did the whole arm control with a few headlight relays. If you shut off the main power switch to the boat, it still retracts the arm. You turn on the "Livewell" switch on the console, and it extends the arm, and enables the power to the Minn-kota motor controller. As soon as you start retracting, the Minn-kota controller is powered off, so no "spinning while retracting" issues.
redbeard
#27 Post by redbeard » Mon May 05, 2014 4:31 pm
Nice job Bob.
tuned
#28 Post by tuned » Tue May 06, 2014 1:09 am
BobG wrote: Actually, I did the whole arm control with a few headlight relays. If you shut off the main power switch to the boat, it still retracts the arm. You turn on the "Livewell" switch on the console, and it extends the arm, and enables the power to the Minn-kota motor controller. As soon as you start retracting, the Minn-kota controller is powered off, so no "spinning while retracting" issues.
Awesome azipod Bob! Good control scheme. It oughta make a great bow thruster for parallel parking! My problem is that I have no room left for such a goody, with the Power Ladder to port and to starboard the Power Anchor and Train Horn :scared
Hmmm. Maybe I can set up an array of Estes rocket 'thrusters'
Good to see I'm not the only mad-scientist electrician around here. I'll have to post some of my Frankenstein band gear sometime. They used to call me Inspector Gadget :biggrin2
killerkernrich
#29 Post by killerkernrich » Tue May 06, 2014 10:57 am
WAY Cool :thumbsup :lol:
PLP Member
NRA member
UFC fan
Cycleman07
#30 Post by Cycleman07 » Tue May 06, 2014 12:46 pm
we need a video of this baby in action. Please and thank you.
