Dent Removal...
Re: Dent Removal...
get the dent less repair guys to fix it
Re: Dent Removal...
What works good on the panels is a softball. Just roll it out with it. If you pound it out you'll get some nasty elephant ears sticking out from the other side. My side panel for the Premier would have cost $1800.00 if it wasn't under a safety recall. They aren't cheap. Depending on your deductible, with the age of the boat, thats the route I would probably go. Actually, if you can just get them to send the aluminum, its easy to install in the railings. But... try the softball approach.
Re: Dent Removal...
is there a chair behind it? if so jam a bike tire inner-tube in there and pump it up it will pop it put. that worked great for BMR on his party cruiser.
Re: Dent Removal...
I would try doing it by hand as much as I could,,shouldn't take much forceCapt. Dan wrote:How do you work it out, with a rubber ball peen hammer or something like that?
[color=#4000BF]2016 Manitou 23 oasis
shp hull 15 1/4 x 19 rebel
52mph 6000rpm
250 ho etech[/color]
52mph 6000rpm
